Gas guage slow to move to Full - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
post #16 of 27 Old 07-04-2004, 11:41 AM
Diablo
Quoted: 0 Post(s)
Mine does it also. When I first got the car, I filled it up @ $24 and like a minute later it was only at a 1/2 tank. At that very instance the thought of selling the car popped into my head briefly but everything turned out ok after 3 minutes . I just never experienced that with a car before. In my Altima it goes up to full even before Im finished pumping the gas.
93 Camry LE & 05 Altima SER-6sp
GaviN is offline
post #17 of 27 Old 07-04-2004, 11:42 AM
Senior TN Member
Quoted: 0 Post(s)
Yeah, same for me.
If you know thats normal (origional poster is fine), whats the big deal! It's not like you don't know your gas tank is full!
1997 Camry CE V6 5-speed!
Mods: Whiteline rear sway bar & nice tires.
2009 RAV4 Limited V6 4WD
Mods: nothing you would care about.
kenratboy is offline
post #18 of 27 Old 07-04-2004, 07:14 PM
Senior TN Member
amerikim's Avatar
Quoted: 0 Post(s)
I remember reading somewhere it's not a good thing to pump gas and have your ignition on to get a gauge reading. Don't know why, maybe it screws the sensor up?
But I do remember that there is a latency built in so you don't get a higher reading when gas sloshes as you are driving around. Personally, if my gas gauge was off, I would rather it tell me its lower then it really is than higher and run out of gas.
My 93 gauge does the same with a full fill up and it seems to run down slow for the first half of the tank then just falls fast. Had me thinking I had a leak or something. I now use the odometer to mark fill ups. Who can trust gauges anyways? First time I ran out of gas was in my ex-g/f's Benz (Bad gauge). Other time was when someone siphoned gas out of my motorcycle.
Do mark milage a couple of times and you will recognize the milage you and your driving style get. It varies very little with me.
old faithful
amerikim is offline
post #19 of 27 Old 07-04-2004, 07:48 PM
Auto-Cross Addict
SmokingTires's Avatar
Quoted: 0 Post(s)
It's normal for older Camrys. It's a feature added in so that you don't get confusing readings.
Say if you were on a hill, you might get a reading that your tank is low when it is. By not giving an up to the second reading, it wont give you and empty reading when you are just at a slant. It's another great feature for the drivers benifit.
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline
post #20 of 27 Old 07-04-2004, 07:52 PM
Quoted: 0 Post(s)
00 camry here, its normal
loserboy is offline
post #21 of 27 Old 07-04-2004, 09:38 PM
On The Street
Quoted: 0 Post(s)
97 camry le, mine does that.
97 Toyota Camry
Live Fast Die Young
famous182 is offline
post #22 of 27 Old 07-04-2004, 09:54 PM
I'm a Mac
zoni's Avatar
Quoted: 1 Post(s)
it goes up all the way right? then whats the problem! would you like the gas gauge to take imediate readings? then your gas gauge would fluctuate incredibly when going up hills, cornering, rapid start/stop driving... ya know... get the drift? it works fine!
zoni is offline
post #23 of 27 Old 07-04-2004, 10:46 PM
Quoted: 0 Post(s)
It's normal, especially for cars where the needle doesn't drop after the key is removed. My Mazda does the same thing.
As someone has mentioned the Gen 5 gauge stays for 10 minutes after the key is out (along with the odometer reading) then the odometer goes out and the gauge falls to E. When you put the key in and after a fill up, it rises to F quickly.
On a side note, I believe they recommend against having the key in the "On" position is because the ignition is on and the fuel pump could run while filling up. Not sure about that one though.
'04 Camry SE V6
'05 Tacoma PreRunner DC TRD Off-Road
BigE is offline
post #24 of 27 Old 07-05-2004, 01:45 AM
Auto-Cross Addict
Quoted: 0 Post(s)
Thanks for quoting me Zoni, haha. Well different words, same ideas.
post #25 of 27 Old 07-05-2004, 10:22 AM
MRQtwinturbo's Avatar
Quoted: 0 Post(s)
the best thing to do to remember ur gas mileage is to reset ur trip odometer each and every time u fill up....my gas mileage is always a good indicator to how my car is running...
91 mr2..07 335i..
MRQtwinturbo is offline
post #26 of 27 Old 07-05-2004, 10:35 AM
I'm a Mac
zoni's Avatar
Quoted: 1 Post(s)
smokey, i didnt even read the thread... sorry i wasnt in the patient reading mood, i just wanted to share my opinion.
zoni is offline
post #27 of 27 Old 07-05-2004, 11:26 AM
doppelkupplungsgetriebe
TRDjibz's Avatar
Quoted: 0 Post(s)
95 camry, yeah i used to wonder toooo, good thing its normal
2015 Jeep Cherokee Trailhawk V6
TRDjibz is offline
User Tag List
Linear Mode Linear Mode
Back
