Spring without struts? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2002, 08:38 AM   #1 (permalink)
Newbie
smokey8890's Avatar
View smokey8890's Photo Gallery
i just put on 17" tires for my 1995 camry le. The rims look kind of small on it so I heard lowering it makes it look better. Can I get away with lowering spring without performance struts?
smokey8890 is offline   Reply With Quote
Old 04-30-2002, 10:49 AM   #2 (permalink)
Luc
View Luc's Photo Gallery
Yes, you can get away without having getting upgraded struts, at the cost of having a bouncy ride, which eventually will wear your OEM struts out. If you haven't changed the OEMs out since you got the car, then most likely they will not last too long with the lowering springs. It's better to get better struts at the same time when you put the lowering springs on, this way, it will save you labor cost next time.
Luc
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
