cold air intake - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2002, 06:40 PM   #1 (permalink)
View camry_dude's Photo Gallery
Is there any company that makes a cold air intake for a 1992 5sfe camry? Just wondering!
Thanks
camry_dude is offline   Reply With Quote
Old 05-11-2002, 09:38 PM   #2 (permalink)
RUN WHAT YOU BRUNG
View 92CAMRYGTS's Photo Gallery
there is no company thats make CAI for our engine. you can buy a HAI but why waste the money. thats what i did. at first i bought a weapon-r before i knew how easy it was to make my own. save your money and go to home depotand spend it there. they have all the air ducting, clamps, and anyhting else you might need to make the intake. i ended up using the weapon-r for the top half and then used air ducting to extend it to the front bumper.
92CAMRYGTS is offline   Reply With Quote
Old 05-11-2002, 10:02 PM   #3 (permalink)
View 98Toyozip's Photo Gallery
Hi,
Is there no difference between
Intakes made by reputated company (Injen) & self made one.
Iam thinking to buy Injen for my 99" camry
What do you think? Are they worth ?
<font size=-1>[ This Message was edited by: 98Toyozip on 2002-05-11 23:02 ]</font>
98Toyozip is offline   Reply With Quote
Old 05-12-2002, 02:09 AM   #4 (permalink)
hey, this might sound stupid but would a celica cold air intake fit in a camry with some modification?
Old 05-12-2002, 11:32 AM   #5 (permalink)
View soundlzrd's Photo Gallery
what engine do you have? Shawn has a celica iceman on his camry
soundlzrd is offline   Reply With Quote
Old 05-12-2002, 11:35 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Make your own.
Check out the site below for instructions.
http://www.teamdelsol.com/howto/coldair/diycoldair.htm
Heres some pics of the one that I made for my gen 2.
Finished product except for the paint:
CAI installed in car:
"Skoolin' the unlearned!"
Old 05-12-2002, 12:54 PM   #7 (permalink)
Den
86 Celica Gt driver
View Den's Photo Gallery
I don't understand one thing~
HOW about the air mass senor?
Den is offline   Reply With Quote
Old 05-12-2002, 09:02 PM   #8 (permalink)
Exactly what parts and tools do I need to make a cold air intake for my gen3 5sfe? Also what is that box thing that 88LE has in the middle of the intake piping?
Thanks
Old 05-13-2002, 10:05 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
Tools - Sockets + ratchet, screwdriver, file, something to cut the pipe with (hacksaw, air die grinder, chop saw, etc..)
Parts - Piping, paint, sandpaper, and hose couplers.
Thats the AFM (air flow meter). Your car uses a MAP (manifold abosolute pressure) sensor so you don't have an AFM. The only thing you need to worry about is the IAT (intake air temperature) sensor.
Old 05-13-2002, 10:26 AM   #10 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
the IAT is an easy install just drill a hole in the pipe u are making and voila!!! u're done!! make sure u clean up the hole u drill dont want any of those to get into ur engine... simple as that... also make sure it is small enough so that it doesnt leak any air through the engine... that way u only get air straight up from the filter...
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 05-15-2002, 04:00 AM   #11 (permalink)
View GreCam96's Photo Gallery
hey 88 LE.. can you teach me how you made your intake. Where did you buy your parts? You helped me with my neons and now they work great. Made my own switch, taped it into the cigeratte lighter and presto. It also beats to the bass in the car. hehehe.. Well thanks for the help, and now I need your help with the intake. Thank you.
GreCam96 is offline   Reply With Quote
Old 05-15-2002, 12:52 PM   #12 (permalink)
Grenaded piston
88 LE's Avatar
Checkout this site:
It'll answer most of your questions.
Piping - Performance autoparts store in town. Its a 2.5&quot; OD (outer diameter) 180 degree mandrel bent u-pipe. The pipe is aluminized steel thats commonly used for exhaust tubing.
Hose couplers - Home Depot
High temp paint - Kragens. Its Dupli-Color high temp engine enamel. Comes in 500 degree and 1200 degree. I used the 500 degree stuff (its available in more colors then the 1200 degree stuff).
Old 05-15-2002, 04:10 PM   #13 (permalink)
hey 88Le.. what are the hose clamps at home depot called? is there a specific name? Also which performance store did you go to? does pepboys sell it? and how much for everything?
Old 05-15-2002, 04:13 PM   #14 (permalink)
also i have a 96 cam le, are you sure the 180 mandrel will fit the specs of the originial intake on my car? thx
Old 05-15-2002, 06:05 PM   #15 (permalink)
Grenaded piston
88 LE's Avatar
Their just rubber hose couplers for pvc pipes. You'll find them in the plumbing section.
They come in different sizes. The ones I used were 2&quot; to 2&quot;. They fit tight onto 2.5&quot; piping, so you just have to jam it on their.
Tognotti's Auto World in Sacramento, CA.
I doubt PepBoy's sells mandrel bent piping.
JC Whitney has what you need, but their a mail order company.
Piping - $15
Couplers - About $4/ea at Home Depot. I think thats how much they were, I forget. I bought 4 of them.
Paint - About $4 from Kragen's.
And I already had all the other parts I needed.
