On 2002-05-13 16:36, Drummer93 wrote:
i know i am going to need piping, intercooler, bov, possibly afc and i figure a fuel upgrade.
An intercooler might not be necessary depending on how much boost you run.
Yes you will need to do something about fuel. More on this later.
i need to know what need besides that, or maybe recomendations where to pick one up for a good price.
Turbo manifold, oil lines + fittings, etc... etc..
Theres alot of parts but, thats all that I can think of for now.
the intercooler and bov i plan to get off an old Starion from a junkyard so those i can pick them up for cheap.
Starion's have a bov? Most factory turbocharged cars that i've seen use a Bosch bypass / recirculation valve.
I suggest that you invest in a good bov like the Blitz dual drive or the HKS ssqv (super sequential). They go for about $200. I myself have a Blitz (older one with big horn).
as for the manifold, i was told i could take it to a local shop that was recomended to me and they can weld into the stock cast iron headers.
I dunno about welding to cast iron. Cast iron absorbs alot of heat and its hard to weld to cos of that.
What you could do is have an adapter made so that you can bolt the turbo to the stock exhaust manifold.
The stock turbo manifold off a 91 - 95 MR2 Turbo will bolt right onto your 5S-FE, but the only turbo that will bolt up to it is a Toyota CT-26 unless you have an adapter to bolt on a different turbo.
I'm using a Garrett/AiResearch T3 along with a turbo manifold from a 91 MR2 Turbo and a custom made adapter (made it myself).
piping, i guess i'll just find somewhere, jcwhitney or something.
JC Whitney has mandrel bent piping.
I bought a few 2.5" OD 180 degree mandrel bent u-pipes (aluminized steel) from a local performance autoparts store. What I did was cut them up to get the pieces I need then weld it all together.
my question is my fuel, everyone i talk to says i have to upgrade my fuel system.
Yes you do.
What we did on Joe's (karma) car was run a MAP sensor from a MR2 Turbo and 360cc injectors from a MKIII Supra.
By the way hes selling the injectors and some other stuff.
You can also fool the stock MAP sensor into not seeing boost and run a fmu / boost dependent fpr.
Additional injectors along with a AIC (additional injector controller). This is the expensive option.
Standalone computer. Something like a Accel DFI, Electromotive TEC II/III, Haltech, Motec, Speedpro, etc.... Most expensive option.
