Upgrade my transmission? Can I use a Zex nitrious kit with a - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2002, 10:23 PM   #1 (permalink)
View ryan_foy's Photo Gallery
I want to try to get some more horsepower out of my camry (it's a 94' 4cyl.) and i don't know if my transmission can handle that much power (aiming for 250). Is there anything i can swap it with? If so where can i purchase one? Also does anybody know if i can use a zex "dry shot" nitrous system with a venom 400 performance chip, or for that matter any other chip or nitrious system. Any finally does anyone know where i can buy a venom 400, cam gears, venom spark plugs, spark plug wires, fuel injectors, new intake manafold, or an exhaust system other than the one at nopi.com
ryan_foy is offline   Reply With Quote
Old 05-14-2002, 10:43 PM   #2 (permalink)
RUN WHAT YOU BRUNG
View 92CAMRYGTS's Photo Gallery
yes you can use the venom 400, but it's not a chip. it is a piggy back computer that hooks up between the tps sensor and another sensor maybe its the mass air flow sensor. i hav it on my car but i've had it on for a while so i forget the wires. noone makes cam gears for our engine, or aftermaret intake manifolds. you can get headers, light-weight pulley, custom cams,intake, nitrous, turbo. most stuff for our engne wuld have to be custom made. you could prob get a custom intake manifold but that might be expensive.
92CAMRYGTS is offline   Reply With Quote
Old 05-14-2002, 10:52 PM   #3 (permalink)
Exactly where can i buy custom parts for my car and how much do you think they would cost where can i buy the header, pully etc.
Old 05-14-2002, 11:23 PM   #4 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
http://www.leitnerbush.com
_________________
Mods & Pics
"One cannot be betrayed if one has no people." --Kobayashi
<font size=-1>[ This Message was edited by: Ratko on 2002-05-15 00:23 ]</font>
Ratko is offline   Reply With Quote
Old 05-15-2002, 01:27 AM   #5 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
ahhh a 4 cyl 5sfe... a dryshot zex kit u wouldnt need a venom400 u can use the one that zex sells with their kit from wat i understand its a better combo... but u'll definitely need a new fuel pump and an additional injector to make the nitrous sytem work.. if u plan on hitting 250 hp not goin to happen with just the zex... u're thinkin of increasing hp from 130hp (stock) to 250 that's over 100shot already nitrous wise.. u'll blow ur motor.. i suggest to get ur motor re done first ie port polished new pistons etc... totally overhaul the motor and give it newer and stronger parts so it can handle that kind of power boost
but to my knowledge the 5sfe can handle a 50-75shot NOS system...
hope this helps.. good luck
humpty
Neoscepter
SCEPTER300RR is offline   Reply With Quote
