I drilled a hole in the top right corner of the firewall. There is a black cover from showing the bare metal, and there is this circle precut from the insulation. I just drilled out a whole from there, but ive heard there is a rubber grommet in the lower right hand side. I heard it requires to remove the panel under the fender. Do a few searches, running amp power for camry or something. Good luck.
Omar
PS to make it easy, just go under the search and search by username and look my name up. Ive for sure said something on that thread, might be easier to locate.
1998 Camry (279,xxx miles)
2002 Camry LE (109,xxx miles)
2000 Solara (135,xxx miles) SOLD
2004 S2000 (98,xxx miles) Supercharged!
