In essence you would pretty much have to remove most of your interior including the dash, door jams,& lower interior panels to get at the whole cabin harness. You would also need to make sure the donor car has the same type of climate controls (Push button or slider), unless you plan on replacing the heater/air cond. housing at the same time (good time to replace your heater core if you are worried about it going out).
Depending on how mechanicly inclined you are, plan to take from 1 to 3 days to do the transplant.
If you do this, keep in mind the harness CAN be removed without cutting any wires. Use a needle nose pliers to undo the clips that keep the harness secure, you should be able to remove most of them without breaking them. When in doubt, take pictures as you go so you have something to reference back to. (You might also be able to help someone else out later.)
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
