Tony,
I was just like you and I couldn't wait either. What I did is measure the stock filter size and I sized it up on K&N's website. The filter I found and am using(part #33-2052) has the same dimensions but it sits taller than the stock filter so the airbox will not close properly. The stock airbox screws are too short to tighten down. They are M5 screws so you should get longer ones like I did.
If you notice, there are 2 ribs on the stock airbox. One on the top and the other at the bottom that spans the entire perimeter. With this K&N filter, it is not groved (it's for a Lexus I think) so it will raise the box that much higher. You can either A) leave it alone and use longer screws (what I did--temp fix), B)grind off the ribs from the airbox to make it fit better (still considering), C) grove the K&N filter on both sides (difficult to do since the rubber is only so thick and there's a metal rod running the length of the filter), or D) screw it and wait for K&N to make a replacement. Well, I couldn't wait so...
Good luck!
SE V6
