60K maintenance - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-25-2004, 09:58 AM   #1 (permalink)
View camryhsane's Photo Gallery
Question 60K maintenance
Simple questions:
I lost my car manual. Is there a website that lists the complete 60K maintenance tasks for a 1999 Toyota Camry, V6 LE.
I just had a tune-up, platinum spark plugs, transmission flush and oil change done. Did I miss anything? unrelated - I also had to change brake pads, two rotos, and two tires.
dumb question: is there a timing belt change to worry about in '99 camry V6?
camryhsane is offline   Reply With Quote
Old 08-25-2004, 10:00 AM   #2 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
yes there is a timing belt also i would change the fuel filter and pcv valve also
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 08-25-2004, 12:19 PM   #3 (permalink)
View spongebob's Photo Gallery
my gen 3 just hit almost 61k and the check engine light did not go on should i just go ahead and do the tune up??
spongebob is offline   Reply With Quote
Old 08-25-2004, 01:32 PM   #4 (permalink)
View Nico's Photo Gallery
You are not supposed to wait 'till engine light goes !!!???
Just do the maintenance : timing belt, oil + filter,...
Nico
Nico is offline   Reply With Quote
Old 08-25-2004, 01:43 PM   #5 (permalink)
i just changed oil on sunday and about a month ago coolant flush and around 58k i did changed the oxygen sensor.
Old 08-25-2004, 02:33 PM   #6 (permalink)
When did you last time change your timing belt ? You could also change your spark plugs...
Nico
Old 08-25-2004, 02:41 PM   #7 (permalink)
Mad Scientist
every 3k miles change oil and oil filter
every 15k miles change air filter (unless you have a ram air or cai system then you need to clean or replace every other oil change)
every 30k miles replace fuel filter service cooling system replace spark plugs replace cap rotor and wires (if applicable)
every 60k miles check valve clearance, change timing belt, fuel cap gasket, replace pvc valve(replace as often if driving conditions are harsh)
Camry Wagon Crew
