I’m changing my rear main seal retainer gasket this weekend. I did it last weekend but it leaked more after we were finished. I think we didn’t add enough gasket maker to the paper gasket that came with the oil seal (Napa). That and/or we didn’t take the oil pan off at the same time we the took the retainer off (the bottom of the retainer makes up one side of where the oil pan bolts up).
I wanted to know if anyone has changed the retainer seal and what tips you may have for me. Usually people just change that main seal because the retainer doesn’t leak.
I will be sure to add more than enough gasket maker as described in the autozone's illustration:
http://autozone.com/servlet/UiBroker...3d8013e79f.jsp
I am also going to the dealer to buy the metal gasket for the retainer. This was the original gasket that came with the car.
I also noticed that I am missing 1 bolt (out of 6) that attaches the flywheel to the crankshaft. Could this be a cause of an oil leak? I read somewhere that if the surface where the crankshaft and the flywheel makes contact is scratched there will be a permanent oil leak. That was for a 300Z but it raised my interests. I still can’t see how oil will come from anywhere near that bolt but its just a question.
Thanks in advance
GEN3 - 5SFE
