gas gauge needle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2002, 11:10 AM   #1 (permalink)
Bollywood Boy
mrbacardi's Avatar
View mrbacardi's Photo Gallery
when i was installing my new gauges i had half a tank of gas, i must have bumped the gas needle and when i put back the gauges and started up my car, the needle read full. Now, if i go and fill up my car, will the needle recaliberate itself? If not, how can i get it recalibrated?
Mr. DIY
mrbacardi is offline   Reply With Quote
Old 05-24-2002, 09:20 PM   #2 (permalink)
Bollywood Boy
mrbacardi's Avatar
anybody?!?!
Mr. DIY
Old 05-24-2002, 11:45 PM   #3 (permalink)
View Louienyc75's Photo Gallery
Thats the only way to tell, if you go fill it up. And if all you did is bump it like you said it should recalibrate itself yes. I know b/c I removed my 91 instrument cluster.
Louienyc75 is offline   Reply With Quote
Old 05-24-2002, 11:47 PM   #4 (permalink)
what can you do with it? Get a perfromance clutch from a number of companies out there.
There are lots of options for third gen camrys like yourself depends what you want to do
Old 05-25-2002, 12:23 AM   #5 (permalink)
Bollywood Boy
mrbacardi's Avatar
ok the needle is at full, and it won't move!! i think i will try to turn it upside down, cause i think i may have turned it upside down when installing the indiglo gauges, thanks
Mr. DIY
Old 05-25-2002, 02:24 AM   #6 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700765
iTrader Score: 6 reviews
View EKam's Photo Gallery
Well why did you remove the needle in the first place? It's not necessary to remove it to install the indiglos.
I would suggest you to take the car back to the dealership to have it recaliberated.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 05-25-2002, 02:36 AM   #7 (permalink)
Bollywood Boy
mrbacardi's Avatar
well technically i didn't remove just the needle, i had to remove this thing that attached the needle to the gauge, and i may have bumped it or i may have flipping it upside down and installed it backwards, but in this situation you definately needed to remove that part
Mr. DIY
Old 05-25-2002, 10:04 AM   #8 (permalink)
EKam's Avatar
It shouldn't affect the needle even if you removed one of the screw off the guage.
I'm guessing either you screwed it up real good, or your indiglo pops back up and got the needle stuck.
Old 05-25-2002, 05:37 PM   #9 (permalink)
Bollywood Boy
mrbacardi's Avatar
i will try to turn it around tonight
Mr. DIY
Old 05-25-2002, 07:53 PM   #10 (permalink)
View tAn_CamRy's Photo Gallery
thats why u shoulda made a note of where your needle was at. i tink all of the other needles had springs on em so it doesn't matter if u touch em. i slightly moved my gas needle when i put in the indiglos but i put it back to how i remembered it to be. and it didn't recaliberate itself
tAn_CamRy is offline   Reply With Quote
Old 05-26-2002, 12:51 AM   #11 (permalink)
rayray's Avatar
View rayray's Photo Gallery
like elegantcam said... check to see that the indiglo gauge face is not popping up and interfering with the movement of the needle. that may be the case.
-rayray
rayray is offline   Reply With Quote
Old 05-26-2002, 03:03 PM   #12 (permalink)
Bollywood Boy
mrbacardi's Avatar
ok i checked the gas gauge needle and doesn't seem like the stuff if popping up, i turned it around and i think i got it working now, but if anything else comes up, i'll tell u guys,
thanks a lot guys!
Mr. DIY
