help with whiteline front bar - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2002, 05:13 PM   #1 (permalink)
SGG
View SGG's Photo Gallery
has anybody else installed the FSB? i know some others ordered it on the last GB. I was going to try today after an oil change, but I noticed that the bushing bolts are in cramped quarters. The rear bolt could be turned with a thin wrench but with small angle increments. Will I be able to torque it close to spec this way? there's no way to fit my torque wrench in there or my ratchet for that matter.
SGG is offline   Reply With Quote
Old 05-26-2002, 12:10 AM   #2 (permalink)
View F1 Chris's Photo Gallery
Yes you can torque it to spec fine. But it does take a long time. It took me 3.5 hours from start to finish. I used the smallest wrench I had.
F1 Chris is offline   Reply With Quote
Old 05-26-2002, 09:49 AM   #3 (permalink)
SGG
how did you check the torque in that tight location? you can email me if it's easier. thanks a lot!
Old 05-26-2002, 09:19 PM   #4 (permalink)
You'll want to get it as tight as you can with your fingers. It'll be about 25lbs.
