Changing O2 sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2004, 07:02 PM   #1 (permalink)
View ObsessionK1's Photo Gallery
Thumbs down Changing O2 sensor
I got a '99 camry and trying to put on the catback I got for it. The bolts I can heat up and just unscrew, but the O2 sensor will not budge. I got a extension thing from autozone and the %$@ thing will not unscrew. Is there some easier way to taking it out, or am I doing it wrong ?
ObsessionK1 is offline   Reply With Quote
Old 09-10-2004, 07:52 PM   #2 (permalink)
View Quickbeam's Photo Gallery
Use a big-ass crescent wrench, lefty loosey. Spray it with some WD-40 or whatever about 15 or 30 minutes before you try again. The expansion rate of the O2 sensor threads is different than that of the exhaust so it's probably jammed in there pretty good.
Quickbeam is offline   Reply With Quote
Old 10-19-2004, 02:28 PM   #3 (permalink)
View japple's Photo Gallery
The O2 sensor might be tightened by the German way "Gut-and-tightht" and + the metal heats up so much, sometimes it resembles a weld in. :] I have to change mine since i am getting the O2 msg = check engine light....We'll see how that goes.
Love Life, get paid to get laid...and if you can't race it or sleep with it, you probably don't need it!!!
http://japple.no-ip.org/NRide.html
japple is offline   Reply With Quote
Old 10-19-2004, 10:59 PM   #4 (permalink)
Official TN P.I.M.P.
trixx's Avatar
View trixx's Photo Gallery
Where exactly is the snesor located? the picture in the haynes manual ain't good enough.
If you can't say nuthin nice, say somethin f*cked up.
trixx is offline   Reply With Quote
Old 10-21-2004, 02:11 PM   #5 (permalink)
it is on the front where the engine exhausts goes out below (not under) the cover of the pipes (with the little - Caution - Hot! sign) is is like a sparkplug and the cable goes up to the engine block.usually has 3 or 4 wires (black, white, blue, gray).
Replay if u get it loose. Use lot's of WD-40 :]
Thanks.
Old 10-21-2004, 05:36 PM   #6 (permalink)
The O@ sensor that I was having problems with was tucked up by the catalytic converter. I just took it to Tuffy's and they were able to get it out with something. I just had them put the rest of my exhaust on as well.
http://members.cardomain.com/bloody
Old 10-22-2004, 10:42 AM   #7 (permalink)
how much did they charge you for the actual sensor? (no labor)
