Changing PCV Valve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-12-2004, 12:23 AM   #1 (permalink)
View [TRD-yota]'s Photo Gallery
Changing PCV Valve
Hello. I have a '95 Camry LE (4cyl) and I was wondering how hard it would be to change the PCV valve and where it would be located in the engine compartmnt. Not much of a mechanic so simple everyday terms would be much appreciated. TIA.
[TRD-yota] is offline   Reply With Quote
Old 09-12-2004, 02:46 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
It plugs into the top of the valve cover.
The other end of it is connected to the front of the intake manifold.
"Skoolin' the unlearned!"
Old 09-12-2004, 11:49 AM   #3 (permalink)
View mike787's Photo Gallery
If have the part, least expensive is at Cdn Tire, it can be done in 1 minute.
mike787 is offline   Reply With Quote
Old 09-12-2004, 11:54 AM   #4 (permalink)
Thanks for the replies. Judging by them, it's easily done and in a fairly short amount of time. Anything I should watch out for? Are there specific types of PCV valves that I need to buy?
Old 09-12-2004, 11:49 PM   #5 (permalink)
Personally I use Fram bec it is less expensive and it is just as good as genuine Toyota parts. All it really is, is a check valve with a spring in it, to permit vacuum/air in one direction only.
