Rack and Pinion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2004, 08:57 PM   #1 (permalink)
pro nub
View trdcamry00's Photo Gallery
Rack and Pinion
has anyone ever replaced this because im am currently in the process and need a little help. I don't know which position to take it out and i can't get it off the steering knuckle
thx
trdcamry00 is offline   Reply With Quote
Old 09-15-2004, 01:26 AM   #2 (permalink)
View Big Blue Truck's Photo Gallery
still need help?
Big Blue Truck is offline   Reply With Quote
Old 09-15-2004, 03:13 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: Rack and Pinion
Unbolt the steering rack, slide it foward (towards the engine), and remove it from the car.
The tie rod ends are bolted to the steering knuckle, so you need to unbolt them. To pop them loose you need a tie rod end puller.
"Skoolin' the unlearned!"
Old 09-15-2004, 11:22 PM   #4 (permalink)
pro nub
Thanks for the help 88LE i should be continuing this over the weekend because i don't have time on the weekdays going to school. Ill let you know how it turned out
thanks
Old 10-12-2004, 01:57 AM   #5 (permalink)
pro nub
i finally put my new steering rack in. Does anybody know the torque specs for the tie rod and the nut that comes right after the tie rod and is connected to the steering rack
thx
Old 10-12-2004, 05:29 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
Tie rod to spindle is 36 ft. lbs.
Not sure about the nut, couldn't find anything about it in my repair manual.
I would just tighten it up till its tight.
Old 10-12-2004, 07:30 PM   #7 (permalink)
pro nub
thanks 88le for all your help. i really appreciate it.
