opinions on SAFC - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2004, 05:39 PM   #1 (permalink)
View I4 to V6 Swap's Photo Gallery
opinions on SAFC
For those who are FI, what kind of SAFC are you running, and how easy were they to install? I have read about the APEX, URD, and Greddy. Are there any others? I am leaning toward URD since there is a kit with the injectors, but I am not certain. Any help, opinions, and their own experiences with the SAFCs would be great. Thanks.
I4 to V6 Swap is offline   Reply With Quote
Old 09-18-2004, 07:48 PM   #2 (permalink)
gLok's Avatar
View gLok's Photo Gallery
My s-afc works allright. Just make sure you get the car tuned properly with it. Guessing on the settings can lead to an engine rebuild.
gLok is offline   Reply With Quote
Old 09-18-2004, 08:43 PM   #3 (permalink)
club momentum moves you !
shook's Avatar
View shook's Photo Gallery
i like my safc as well but im wondering what everyone has their sensor votage setting at ? are the ECUs on 5sfes 4volts or 5volts ? im running a turbo mr2 pressure sensor and i have mine set at 4in and 4out.. is this wrong ? should it be 5in and 5out ? or 5in and 4out ? let me know please ! thanks ;D
shook is offline   Reply With Quote
Old 09-18-2004, 08:51 PM   #4 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
I've been running the Apex-i SAFC for some time now without any probs. It yielded 10whp @ 4psi. Worth every penny.
You can DL the manual from http://www.apexi-usa.com/documentation.asp
Installation is a matter of sniping one wire and tapping the rest like this http://www.pbase.com/toycam/image/12448592
Here's a diagram for the 1MZ-FE ECU pinout http://www.pbase.com/toycam/image/12448593
As for making adjustments, it's fairly easy. Most tuner shops are familiar with them. Ask to make sure of course.
*Note: install may be diff for your application.
Edit: forgot to ask...how aggresive do you intend to do with your setup? The SAFC has limitations.
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 09-19-2004, 12:01 AM   #5 (permalink)
Gameroom cash: $147537
The 4in 4out is not voltage, its "sensor type 4".
Got SAFC, never did set it up. Will do that after I P&P and rebuild the engine. Definitly need a dyno to tune.
Old 09-19-2004, 12:26 AM   #6 (permalink)
shook's Avatar
ok, so what should the sensor no. be set at when using a mr2 turbo pressure sensor on a 5sfe ecu ? what does everyone who has a apexi s-afc have it set it ?
Old 09-20-2004, 12:45 AM   #7 (permalink)
Sweet. Thanx for the info.
