Rough and shaky Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2004, 02:58 PM   #1 (permalink)
View png6778's Photo Gallery
Unhappy Rough and shaky Camry
I have 96 Toyota camry 4 cyl with 145K. I bought it used some one and a half years back. It runs smooth, but i have one problem with it. Whenever i drive it for long distance say for 100 miles or more it becomes rough when i stop at a signal and the engine rpm goes up and down and then it stops. It starts when i turn in the key again but again it is rough. The engine seems to shake at the time when it is rough. If at that time i drive it without stopping anywhere, it runs fine, but it is rough again when i stop. If i leave my car stopped for a while (20-30 mins), it operates normally. Can anyone please help me with this problem.
png6778 is offline   Reply With Quote
Old 09-21-2004, 05:35 PM   #2 (permalink)
View karazy's Photo Gallery
It could be a vacuum leak, but it wouldn't hurt to check the plugs and filter.
It could be worse, but start with the easy stuff.
karazy is offline   Reply With Quote
Old 09-22-2004, 01:22 PM   #3 (permalink)
Thanks for the input. One of my friend suggested to change the PCV which i haven't change since i bought the car. I am not sure whether it would help.
Old 09-22-2004, 01:27 PM   #4 (permalink)
Sold out for a Max
TheMajesticking's Avatar
View TheMajesticking's Photo Gallery
Wait. Mine does that. Whenever I run it hard for a little while and come to a complete stop it acts like it's going to cut off and the RPMs go really low. It doesn't shut off though.
-Chris
TheMajesticking is offline   Reply With Quote
Old 09-22-2004, 05:01 PM   #5 (permalink)
It could be the EGR valve as well.
Old 09-22-2004, 10:41 PM   #6 (permalink)
Pissed
View Camryamnesty's Photo Gallery
could be cuz ur ac is running lol, ive noticed that mine does that a lil, but only when my ac is running umm i cant think of anything except of what has already been suggested
Camryamnesty is offline   Reply With Quote
Old 09-22-2004, 11:35 PM   #7 (permalink)
I face the problem whether or not AC is on or not on. I will first try with changing PCV valve (it is costing $15 at dealer), then i will move to changing EGR if it does'nt work. Checking Vaccum leaks is costing $75 at delaer which i will try at the last. Thanks for so many suggestions. Any idea where i can get cheap EGR valve ?
Thanks again... I will update this post with whatever happens after I go to the dealer.
Old 09-23-2004, 08:40 AM   #8 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $912127
iTrader Score: 59 reviews
Hey, stay away from the dealers in Richmond Va, esp one on midlothian turnpike, they lie and steal!! There's a place on brook rd called Vidlers, this guy recently did some work on my daughters camry (99) and my camry(96), seemed honest, and knowledgable , reasonable too! Kinda sounds to me like ya need a good tune up and maybe your injectors cleaned, It can get expensive throwing parts at a problem when your not sure what the problem is , I've done that before (more than once) Good luck!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 09-23-2004, 10:28 AM   #9 (permalink)
Ii have taken my car to 2-3 shops and explained my problem, but they were not able to do anything saying that they could not reproduce the problem. The problem that i faces does not happen often, only sometimes otherwise my car runs smooth. I have already done work on fuel injectors from Mrchant's. Tune up is one thing that i was also thinking of getting done.
Old 09-23-2004, 04:00 PM   #10 (permalink)
Super Moderator
eyeball96's Avatar
Plugs, wires, and cap may fix your problem esp at 145k, call Bo at Vidlers automotive 266-9636, He seemed honest to Me!!!
