Originally posted by GreenPunkBlood
anywyas, are there any common problems with this car that i should look out for when buying one?
Rust is #1.
There was a recall on the '91 models because the stock radio would short out and catch fire. Chuck it in the trash and get another head unit.
A hear a lot of complaints about trunk leaks (again, depends on where you live).
The dome light contacts are crap (corrode very easily).
Automatic trannies (A140L and A140E) are so-so. Some people don't mind them. Other's say that suck or call them "slush boxes".
Electrical wiring is kinda sorta wonky, but a lot of that is probably age and corroded ground contacts.
There are a few common issues with the 3S-FE such as a crappy Bosch starter motor where the pinion gear would slip and tear up the flywheel (another recall). Also, the seals on the dizzy and valve cover will break down and leak oil. The CA models have two cats and two oxygen sensors, which can be a PITA. Also, the primary cat clogs/melts after a while and is bank to replace (better off gutting it). The 3S-FE isn't very well harmonically balanced either.
If you're swapping the engine, that last paragraph is less important to you.
Otherwise, they're pretty solid cars if the previous owner took reasonably good care of it (the PO of mine abused it, so I had/have to do a lot of work).
- John
