sluggish starts in the morning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2004, 04:17 PM   #1 (permalink)
View alex86's Photo Gallery
ive been wondering bout y my 88 camry has a sluggish start in the morning and sometimes in the afternoon when engine is cold. it would crank but it b like sputtering after a few seconds later. then when i shut the engine off nd start it bak up it starts instantly. wth is the problem? mechanic said batter but he checked nd he was wrong. prob spark plugs?
alex86 is offline   Reply With Quote
Old 09-23-2004, 04:39 PM   #2 (permalink)
back again? yeah, i am.
Erbe's Avatar
View Erbe's Photo Gallery
sparks mayb...prolly something with the ignition...it could be sluggish jus cus its an old car and its cold
back for the very first time.
-pat
Erbe is offline   Reply With Quote
Old 09-23-2004, 04:40 PM   #3 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
if you haven't changed your plugs in a while, it'd probably be a good idea. I'd also clean out your ICV valve and look into your starter.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 09-23-2004, 07:30 PM   #4 (permalink)
thx guys ill try those out
I have been given a sickness from the doc... Obsessive Compulsive Camry Dissorder... certifiable
Old 09-23-2004, 07:59 PM   #5 (permalink)
Diablo
View GaviN's Photo Gallery
My Accord used to start really slow whenever it was really cold outside and sat still overnight..
93 Camry LE & 05 Altima SER-6sp
GaviN is offline   Reply With Quote
Old 09-23-2004, 08:46 PM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Check the start injector time s/w (cold start timing switch) and cold start injector.
Start injector time s/w is located on a neck that bolts to the right side of the cylinder head. The upper radiator hose goes into it.
Cold start injector is located on the intake manifold. Its in the middle right underneath where it says EFI.
Cold start injector
2-1: 12 volts while start injector time s/w is closed and starter cranking.
Points open above 35C (95F).
2-1: Approx. 20 - 40 ohms below 30C (86F).
2-1: Approx. 40 - 60 ohms above 40C (104F).
2-ground: Approx. 20 - 80 ohms
2-1 means pin 2 to pin 1 on the sensor.
2-ground means pin 2 to ground on the sensor.
All measurements are taken at the sensor.
My bet is on the start injector time s/w.
"Skoolin' the unlearned!"
Old 09-23-2004, 09:55 PM   #7 (permalink)
View 97 camry xle's Photo Gallery
i dont know if this has anything to do with it, but my cam always seems to start better with more gas in the tank
*rehab is for quitters*
'97 camry xle
'92 bmw 535i
97 camry xle is offline   Reply With Quote
Old 09-23-2004, 10:10 PM   #8 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
if it really seems like its struggling in the cold and everything seems to be alright, then you can also try using different oil.....like, some winter blend or something....higher viscosity = less friction = easier starts
HaHa
