No Break Lights!!
I have a 90 camry,the rear brake lights dont work,the tail lights and break lights are the same bulb according to the manual and theyre on all the time as tail lights but nothing happens as a break light when the breaks are stepped on,changed bulbs,changes fuse,still no break lights,am i reading the manual wrong and are the brake lights seperate from the tail lights,above the brake/taillight is the turnsignal,works fine,then on the movable part of the trunk at the bottom are tail/brake lights,tail lights are always on but nothing happens when breaks pressed,and above that is the reverse lights which work fine,so if the brake light and the tail light are the same light bulb why doesnt anything happen when i press the brake or am i missing something,dont want a ticket for this one,thanks
