excess ripple detected - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2004, 01:13 AM   #1 (permalink)
battlekat49's Avatar
Location: west coast, best coast, aim it at your chest coast...
View battlekat49's Photo Gallery
what the hell does that mean? recently my battery has been crapping out on me in the morning so i took it to my boy who works in the automotive department at sam's club and had it tested and it was down to 336 CCA and when he tested the starter it with some other contraption and the print-out said there was an excess ripple detected, he has no idea what that means. so can anyone tell me what that is. also the next day, today, i took it to the dealership and they said the battery was borderline needing replacement. they said they can test the charging system for $62.50 and i said no and then they saw the 4AWG wire for my stereo and then became worried about blowing up my stereo system. i told them to just pull the fuse and there wouldnt be a problem but they were scared nonetheless. so back to my original question, what does "excess ripple detected" mean? it came up when my friend tested the starter.
tha thundertank!
battlekat49 is offline   Reply With Quote
Old 09-25-2004, 05:48 AM   #2 (permalink)
View karazy's Photo Gallery
It means the rectifier in the alternator is not properly changing the AC to DC.
karazy is offline   Reply With Quote
Old 09-25-2004, 05:41 PM   #3 (permalink)
thanks. how does one remedy that problem and what could have caused it?
tha thundertank!
Old 09-26-2004, 04:16 PM   #4 (permalink)
Some of those checkers are programmed to be a little too picky. Just because there is excess ripple, does not mean it is toast. If you can still read around 14VDC coming from the alternator it is still good. As Redd Foxx used to say " a little ripple never
killed nobody."
I'm not sure what is available as a repair kit for your alt, if it checks out bad. It's an electronic part, they just go sometimes.
Old 09-26-2004, 07:34 PM   #5 (permalink)
i was getting 14vdc from the old battery but as i said the dealer told me it was borderline needing replacement. i put in the optima yellow top and now the car fires up like a champ but how do i test the alternator?
tha thundertank!
Old 09-26-2004, 07:38 PM   #6 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
get a volt meter and install it on your car as well as a amp meter then you'll have all the info you need constantly
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 09-26-2004, 08:53 PM   #7 (permalink)
If you were getting 14v from the almost dead battery, the alt must have been connected and running. Sounds like it's OK. If you want to check it again, just put the voltmeter across the battery with the car running. Chances are if the charging light didn't come on, it's alright.
Old 09-26-2004, 09:49 PM   #8 (permalink)
i want to get the cobalt voltmeter and ammeter from autometer but those are expensive as hell.
what charging light are you talking about? i'll try it later when i get home.
tha thundertank!
Old 09-27-2004, 04:07 AM   #9 (permalink)
The one in the dash that looks like a battery.
Old 09-27-2004, 07:53 AM   #10 (permalink)
97 BlackWidowed
View Porkch0p220's Photo Gallery
a machanic once told me this disconnect the negitive side of the batt and fire it up if it dosent start the altinater is bad... never tried it. i just replaced the altinator i got a reman one of ebay for like 50 bucks with a warrentie, it was worth it
Porkch0p220 is offline   Reply With Quote
Old 09-27-2004, 09:05 AM   #11 (permalink)
That is the most messed up thing i've ever read. How is a car going to start with the battery disconnected?
Old 09-27-2004, 09:12 AM   #12 (permalink)
Mad Scientist
^that mechanic is an idiot
battlekat49:just get some standard gauges so you can keep an eye on your motor.
i have sunpro gauges(mechanical oil pressure,volt.,amp) cause it's all i could afford at the time. and i'm happy with them. i plan to get one for my oil temp and a pyrometer but those are in the future
Camry Wagon Crew
Old 09-27-2004, 10:59 AM   #13 (permalink)
engineer in training
Gameroom cash: $145055
he most likely meant start the car and disconnect the negative terminal, if the car still runs with the battery disconnected the alternator is ok
Old 09-28-2004, 12:25 AM   #14 (permalink)
so you're saying to test the battery with the engine running and to take note if the light in the dash comes on for the battery. if it stays off it's ok, if it comes on... the alternator is messed up?
tha thundertank!
Old 09-28-2004, 01:44 AM   #15 (permalink)
i dont know what you mean by test the battery, but you can try starting the car and disconnecting the battery, the car should idle no problem with the battery disconnected (mine will) but if there is an alternator problem it will probably die or start running funny
