smoke briefly at startup - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2004, 05:32 PM   #1 (permalink)
View DailyDriveCamry's Photo Gallery
Hey all, just got this 94 LE Camry i4, and I notice that it blows white smoke out the tailpipe when you first start it. Does this for about 30 seconds, medium sized amount that gets weaker and the smoke stops completely within 30-60 seconds of startup. Seems like it is doing this a little more each day. Drives fine, revs fine, not sure how serious this is. I've been told that my harmonic balancer was bad, but don't know if that has anything to do with it. Any ideas or simple/free things I can test?
DailyDriveCamry is offline   Reply With Quote
Old 09-27-2004, 05:46 PM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
White smoke is coolant definately not good, time for a mechanic, or to learn how to take the head off the engine!
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 09-27-2004, 08:25 PM   #3 (permalink)
View toyotanut3717's Photo Gallery
Could be valve stem seals leaking as well.
toyotanut3717 is offline   Reply With Quote
Old 09-27-2004, 08:39 PM   #4 (permalink)
Forgot to add that I bought it from the owner of a mechanic shop who had gotten it with a dead engine and replaced it with another engine that had 70,000 miles on it. That's what I was told anyway.
It's only been driven on the replacement engine for a week now.
Hitting someone at 30Mph that has a 14" trailer hitch leaves a lasting impression on your car...
Old 09-27-2004, 10:54 PM   #5 (permalink)
40x40 pixels is crap !
Velox_camry's Avatar
View Velox_camry's Photo Gallery
sometimes white smoke can be as simple as putting too much oil in your car, like during an oil change... the excess oil can squirt into your piston while firing and will temporarily create thick white smoke. i hope thats the problem... to see if it is try changing your oil. hope that helps !
"Guardrails...those things that separate the men from the boys."-Fumiaki Komatsu
Velox_camry is offline   Reply With Quote
Old 12-18-2004, 11:32 PM   #6 (permalink)
Mitsubishi Diamante Owner
CDub LXi's Avatar
View CDub LXi's Photo Gallery
I have an 01 Camry with 82,000 miles on it. The oil has been changed at intervals no longer than 4k miles (usually about once a month). Mine is doing the same thing. I only have the Toyota dealership near my apartment do my oil changes. Mine only does it when it's been sitting overnight. It does it for roughly 10-15 seconds then stops. It doesn't smoke when I drive it.
BTW, the car has NEVER been above 4k RPMS and rarely above 3K RPMS.
CDub LXi is offline   Reply With Quote
Old 12-18-2004, 11:54 PM   #7 (permalink)
View warlock's Photo Gallery
smoke at start up is common in older motors.as long as it stopes shortly after.that is the valve seals.if it doesnt stop you have a bigger prob.
94 Scepter 1MZ-FE
< TN Type [R]ice Club>RICERS UNITE!! Join Type R..latest faction of TN!!
.....http://www.toyotanation.com/forum/sh...d.php?t=105457
warlock is offline   Reply With Quote
Old 12-18-2004, 11:58 PM   #8 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
Sure there are! Take it over to your local auto parts store(Napa, Schucks/CHecker Auto, whereever) and show them whats happening.
DO you have a check enigne light?
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 12-19-2004, 12:02 AM   #9 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
are you sure this isnt just the normal cold day/cold engine white feathery smoke that is normal on all engines when its cold?
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 12-19-2004, 12:03 AM   #10 (permalink)
userlain's Avatar
More specifically the moisture in the exhaust condensing like breath?
Old 12-19-2004, 12:08 AM   #11 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Harmonic balancer, not.
A little white smoke is normal especially starting first time of the day.
Theres always a little condensation from a hot pipe in cooler air. Especially if its wet and cold. I remember water turning to steam increases in volume by approx 1500% - a little bit of water makes a lot of steam.
Now if it doesn't stop and gets worse - thats a whole different ball game.
You then start to think about blown head gaskets and cracked blocks.
Other telltale signs would be bubbling in the radiator, oil in coolant or coolant in oil.
I really don't think you have a problem.
amerikim is offline   Reply With Quote
Old 12-19-2004, 07:24 AM   #12 (permalink)
CDub LXi's Avatar
That's what scares me. I'm probably just going to ignore it until it gets worse but it smells like it's something worse. Like I said, it only does it on my car for a few seconds then stops.... and when I'm driving on the freeway it doesn't stink.
Old 12-19-2004, 07:44 AM   #13 (permalink)
View solaraguy672's Photo Gallery
mine does this everyday. its normal i dont think anything is wrong w/ ur car its just warming up in the morning. could be wrong tho ask ur toyota dealer i guess
2000 Solara SLE V6
Looking into an Acura RSX
www.cardomain.com/id/jdmpwr07
solaraguy672 is offline   Reply With Quote
Old 12-19-2004, 09:19 AM   #14 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Worn valve seals. Its a common problem on Camrys.
Mine started doing it at around 80,000 miles.
Your looking at around $600 - $700 to replace the seals if you have it done at a Toyota dealership.
"Skoolin' the unlearned!"
Old 12-19-2004, 01:17 PM   #15 (permalink)
userlain's Avatar
What does it smell like? Gasoline?
