Sway Bar Bolt Sizes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-29-2004, 11:46 AM   #1 (permalink)
View Calvin327's Photo Gallery
Sway Bar Bolt Sizes
Hey guys and gals, anyone one know what the bolt sizes are on the rear sway bar of the 3rd gen camrys? I believe there are six bolts. Two on each bushing bracket and one on end endlink. I'm afraid to remove mines because it seems to be really rusted in there, for those who have already taken them off and change their sway bars please let me know. I have also went to the dealer and they couldn't tell me crap.
P.S. I have a 94 5sfe camry
Thanks,
Calvin
Calvin327 is offline   Reply With Quote
Old 09-29-2004, 03:08 PM   #2 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
14mm for the end links and use an allen key to assist you when removing those. and either a 14mm or 12mm socket for the ones that hold the rsb in place
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 09-29-2004, 03:09 PM   #3 (permalink)
Thanks a lot man!!! so the outter two bolts are 14mm, what about the ones on the bushing brackets?
Thanks
Old 09-29-2004, 03:16 PM   #4 (permalink)
Mad Scientist
i think they are 14mm or 12 mm not sure cause i was watching my son at the same time.
but i would suggest lowering/removing your exhaust to do this that way it will make it alot easier on you.
Camry Wagon Crew
Old 09-30-2004, 12:30 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ Yup its either 12mm or 14mm (I forget).
To remove the nut on the endlinks you need a 5mm allen wrench to hold the stud. Then use a closed end wrench to remove the nut.
Soak down the nuts and bolts with WD-40, PB Blaster, etc.... before removing them.
"Skoolin' the unlearned!"
