2.4 4 cyl vs. 3.3 V6 - resale and general motor quality
I'm looking at 2005 Solara's in 2 setups:
SLE (4 cyl)
SE Sport V6 w/sunroof
I am working within a certain price range so the SLE V6 is out of the question
Both automatics . It's for the wife.
My wife drove a 4 banger SLE and loved it. I was in the back seat and she didn't step on it by any means, so I could get no feel for how much the little 4 banger moves out.
In general I'd rather have a V6, but the SE Sport V6 lacks a few features the SLE has, namely auto A/C and power seats. Not a deal break considering the tradeoff is having a V6. My wife can make due with either car.
I'm trying to get an idea for the quality of the 4 cyl and V6 engines in these cars. Are these new engines or have they been around a while? Are they good engines, and in particular, is that 4cyl a good engine that will LAST and not loose all of it's get up and go after 2-4 years.
Lastly, is there any precedent for resale value on solara's or camry's with 4cyl vs. the V6's.
Nothing to be worried about... those 4cyl engines that toyota make will last for years and years to come without losing any power.... and with that engine in there, with VVT (Variable Valve Timing), will improve effeciency over the older engines.
I got a 9 year old camry le with a 4cyl.... with 150k miles... and it still runs the same way when it was bought in in 1997.
My buddy has a 1980 toyota pickup truck, and its all hanging by a few strings... but the engine still has a big strong chain attached to it (so to speak), it has over 300k miles, gets abused every day, theres never any oil in there, and it still holds strong...
the point is, toyota makes the best 4cyl engines on the market, the engine in there, when you said "had it been around for a while", they are built brand new, they dont just grab an engine off the shelve thats 5 years old and put it in there.
"had it been around a while" meant is it an existing engine design they have been using for the past years, or was it a newly introduced engine this year. I'm not one to be an early adopter and might be skeptical about buying a brand new car that has a brand new engine that they just released.
A re-tweaked existing engine is fine with me, but it's brand new, built from the ground up, I prefer to let others have the first hand.
Good to know the 4cyl toyota motors are going strong. Ther is a 4cyl SLE that has what we want, but I'm having ahard time finding a SE Coupe V6 that is optioned the way we want. So the 4cyl may be the one.
in all honesty i would go with the i4 instead of the v6 cause the v6 uses a plastic type of intake manifold and from what i remember gm has been doing that and getting alot of problems with longevity. if you plan to keep the car stock don't skimp out cause what helps the value stay longer is when you have options on the car.
Good informatiom, thanks a lot. If this 4cyl is used in the tC, and the tC is going to have a TRD supercharger, is there a supercharger available for the Solara's already that will fit on the 05, or is one coming out? 200hp is more appealing then 157.
the supercharger should fit the engine, but im not sure if it'll fit in the engine bay...
there might be clearance, and ECU issues...
just like the 1mz-fe supercharger available for the 97-01 Camry's/Solaras that didnt fit in anything else without modifications, even on a car with the same engine...
__________________ 1986.5 5-speed '91 7MGE 1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff 1992 5-speed hardtop - 2JZ-GE 2005 Scion xB - no longer stock
I just pulled into the driveway with my 2.4 L. The power is fine for getting around town, driving the freeway and for acceleration. But then I have a 5 speed stick on my SE so I can push the RPMs on up there.
The 4 cyn does fine, plus you can add an better air intake of high flow box filter for a little more kick.
Camry SE '03 2.4L Gen. 5 - Black
Manual Transmission
K&N air filter
Grounding system - Homemade
Enkei Wheels 16 in. 5-spoke alum
The 3.3L isn't "brand" new. The MZ-series V6 has been around since 1994 or 1995 IIRC, as the 1MZ-FE 3.0L that everybody is familiar with. Its been the Toyota workhorse V6 for their front-drive cars for a decade now, used in everything from the Camry V6 to the Sienna minivan, to the RX300. The 3.3L is simply a bored out (not stroked) 3.0L 1MZ engine. It's still based on the same family of engine which is already a proven design. I think the sludge issues are very exaggerated, and were fixed from 2002 and onward anyways.
The AZ series 4-cylinders were actually released in the 2001 RAV-4 (1AZ-FE, 2.0L) and the 2001 Highlander (2AZ-FE, 2.4L). I'd consider these to be "brand spankin new" engines since it's an all-new design and engine family. The 2.4 isn't simply an enlarged 5S-FE 2.2L from the previous Camry and other cars (S-series engines) and called a "6S-FE".
I really wouldn't worry about newer designs when it comes to Toyota. They put so much R&D into their mechanicals that it's just crazy.
Originally posted by nokay The 3.3L isn't "brand" new. The MZ-series V6 has been around since 1994 or 1995 IIRC, as the 1MZ-FE 3.0L that everybody is familiar with. Its been the Toyota workhorse V6 for their front-drive cars for a decade now, used in everything from the Camry V6 to the Sienna minivan, to the RX300. The 3.3L is simply a bored out (not stroked) 3.0L 1MZ engine. It's still based on the same family of engine which is already a proven design. I think the sludge issues are very exaggerated, and were fixed from 2002 and onward anyways.
like you said, it's not brand spanking new, but it is new...
there are a bunch of differences, such as you'll be fucked if you break a timing belt, where as the 1mz-fe is a non-interface design. Also drive by wire, or something, it's not JUST a stroked 1mz-fe...
especially since you gotta get to the 2mz-fe before you get to the 3mz...
From what I've read (no idea if it's just internut BS or for real), the non-VVTi 1MZ's are non-intereference and the VVTi 1MZ's are interference. Since all the MZ series engines in the US have VVT-i, I'd say that both of the current 1MZ and 3MZ engines are both "interference" types. That's just maintenance related though. You should change the timing belt at the specified interval anyways. It's just a question of how much damage is caused if you neglect the car. As long as you're going to do proper maintenance, I wouldn't even say int vs non-int engine designs come into play in at least my buying decisions. If you're younger and very cash strapped and won't be able to afford the timing belt change, then get the 4-cylinder. Maintenance costs are very much part of considering a car and something you should look at. And ETC systems can change the feel of an engine, but the original poster was asking more about whether its a mature design or not, and it is.
Originally posted by nokay From what I've read (no idea if it's just internut BS or for real), the non-VVTi 1MZ's are non-intereference and the VVTi 1MZ's are interference. Since all the MZ series engines in the US have VVT-i, I'd say that both of the current 1MZ and 3MZ engines are both "interference" types.
this is very misleading
my mechanic friend told me his friend has a gen 4 camry v6 1mz-fe, the timing belt slipping because the belt teeth stripped.
all he did was replace a new timing belt, and the engine starts right up.
and not all MZ engine are in US have VVTi, 1MZ-Fe engine was introduced back in 94, and 1MZ-FE VVTi engine was mounted in partial 03 camry v6 and on. but 1mz-fe vvti V6 started as early as 99 on lexus model and later avalon.
I dunno if this helps but i have a 96 avalon (1mz-fe) and it runs fine now. I only have problems with the evap vents (according to the engine code). It currently has 215,000 miles on it.
Av·a·lon n.
In Arthurian legend, an island paradise in the western seas to which King Arthur went at his death
