Lowering the car while keeping stock struts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-08-2002, 07:02 PM   #1 (permalink)
View 96CamrySt4's Photo Gallery
My friend just emailed me this zip file... and I thought it was interesting what it contained about lowering cars and keeping stock struts vs. getting new struts.. check out this link, i posted it on my geocities site.. tell me what you think..
http://www.geocities.com/fattyw/comparison_of_40mm.htm
peace
96CamrySt4 is offline   Reply With Quote
Old 06-09-2002, 02:47 AM   #2 (permalink)
I am just a newbie!
Tony the Tiger's Avatar
View Tony the Tiger's Photo Gallery
It doesn't really make too much sense... what the diagram is demonstrating is just the different spring purge heights... it never mentioned about the higher spring rates on aftermarket springs or more dampening from aftermerket struts. The coilover doesn't necessarily retain "stock" ride quality.. if the coilover is being compressed as the same rate as the stock ones (without a higher spring rate and higher dampening), it would just scrape everything under the car!
* Goal for 2012 -- 200+ MPH in the Camry
Tony the Tiger is offline   Reply With Quote
Old 06-09-2002, 04:57 AM   #3 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
coil over?? no chance... bad ride esp with stock struts.. which btw bounces much much softer than after market so it will feel so bouncy on that car.. ur cornering may improve by a bit but it would be better on better struts...
humpty
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 06-09-2002, 09:24 AM   #4 (permalink)
getn groceries in style
jwa276's Avatar
View jwa276's Photo Gallery
if its a true coilover system, then the ride quality would be next to stock. generally on a true system you can adjust everything (height, dampening, rebound.. etc). on your everyday coilover sleeves (ground control,vis,others) which is just a coilover sleeve with a spring, the ride quality is much harsher, because they manufacture the spring to be much stiffer. if you get a real coilover system (over $1000) you can slam the car and still have good ride quality, just because of the way they are made. you buy a system in which the strut is manufactured together with the spring... hence coilovers
jon
jwa276 is offline   Reply With Quote
