Answers lead to more questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2002, 05:28 PM   #1 (permalink)
View Mr.Incognito's Photo Gallery
I recently emailed burien and asked what they do about the MAP sensor problem and I got this reply:
"We use a map sensor off a turbo"
Hmm..this is neither reassuring nor informative, I didn't think turbos came with map sensors. I am going to email him back but I just wanted to run this by you guys unless I am mistaken or something.
Mr.Incognito is offline   Reply With Quote
Old 06-11-2002, 01:37 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Why not?
The ECU needs to know how much air is going into the engine so that it can add the proper amount of fuel. Thats what a MAP (manifold absolute pressure) sensor is for.
The stock MAP sensor on a 5S-FE is not calibrated for seeing boost. If it sees boost (positive manifold pressure) it'll trip out and fuel cut.
Burien Toyota's solution to this is to use a MAP sensor from a MR2 Turbo and 360cc injectors from a 2JZ-GE (engine in MKIV Supra).
"Skoolin' the unlearned!"
Old 06-11-2002, 02:30 AM   #3 (permalink)
Ah, that's what I was looking for, I wasn't sure what turbo they were talking about. btw, what cc are the stock 5sfe injectors?
Old 06-11-2002, 01:50 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
213cc's / 20lb. hr.
Old 06-11-2002, 02:53 PM   #5 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
213cc's / 20lb. hr.
88LE are you and karma running this Map sensor ???
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 06-11-2002, 09:13 PM   #6 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
Hey Wraith, do you or any of your contacts know the stock rating of the 1MZ injectors?
thanks man, latez.
ratko.org
Ratko is offline   Reply With Quote
Old 06-11-2002, 09:41 PM   #7 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
thanks man, latez.
I'll find out. But, I do know this the engine pop before the injectors run out of room...
MySpace:
Old 06-12-2002, 05:24 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
Joe (karma) is running that MAP sensor.
I have a 3S-FE so I have a AFM. No MAP sensor.
