Strut dust boots? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2002, 06:57 PM   #1 (permalink)
View 93camryv6's Photo Gallery
Im replacing my struts. Are the dust boots necessary? My current ones are useless seeing as they are all ripped.
Also where is the chepest place to get them. The dealership wants $140 for these 4 pieces of rubber.
93camryv6 is offline   Reply With Quote
Old 06-12-2002, 03:57 AM   #2 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
i bought mine for about 40 bucks... i got it from a car parts dealer and the brand is suspension techniques i think... but its on order i get it probably in one more week...
humpty
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 06-12-2002, 05:33 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The dust boots protect the shaft on the struts. It also keeps the shaft from getting dirty.
I know that with my Tokico's the dust boots have to be installed. If you don't install them and the struts blow out they won't warranty them.
"Skoolin' the unlearned!"
Old 06-12-2002, 06:31 AM   #4 (permalink)
View dj14901's Photo Gallery
KYB sells strut boots for the Camry, part # SB101. Summitracing.com carries them, just search under "manufacturer's part #", select "KYB", and then type in "SB101"...
Hope that helps...
DJ
dj14901 is offline   Reply With Quote
Old 06-12-2002, 06:37 AM   #5 (permalink)
PIMPED OUT GEN2 OWNER :P
View HIP2HOP's Photo Gallery
hey all one question i wanna know about struts....
i got a 1.5 inch drop from sum pedders springs on stock struts... not only is this drop not enuf... but the suspension is really bouncy.
So ino if i get new struts the ride will firm up alot... but i also wanna know if i can get struts that lower the ride height even more? im thinkin like 2 inches mo' in the front and 1 inch at the rear
White 1989 Gen 2 Camry (Engine:S1-Ci)
16" Holotype R Rims / 2 Inch Drop with reset pedders springs /2" Sports Exhaust with Lukey UltraFlow Muffler with 3 1/2" Stainless steel tip / Pod Filter http://www.geocities.com/biggpara/pics/index
_________________
mmm.... sexy, sexy....
HIP2HOP is offline   Reply With Quote
Old 06-12-2002, 07:23 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
This is what happens when you have lowering springs and stock struts.
I suggest that you replace the stock struts with some performance ones like KYB, Tokico, Koni, etc..
Struts don't lower the ride height, springs do. :grin:
Old 06-12-2002, 09:46 AM   #7 (permalink)
yeah i'll look into getting sum...
Damnit... that means i gotta get new springs if i wanna lower it more...:sad:
BTW wat are KONI Adjustables? wats adjustable if u cant change the ride height?
Checkout the pix on the link below... u see how the wheel arches dont seemed to be filled enuff, especially the front...? Why the hell dus the rear look lower than the front?
88LE u have that problem man?
Wat R all your opinions on my ride height u's reckon i need to get it lowered more?
ThanX in advance
_________________
Old 06-12-2002, 10:12 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
The dampening is adjustable.
I belive the Koni yellows are adjustable on the rebound stroke, while the reds are adjustable on the rebound and compression stroke.
Mines the other way around. The front is lower then the rear, but thats the way the Intrax springs are for the 2nd gen's.
The rear on my car didn't get lowered all that much so I chopped off a coil off the back springs.
Before you guys give me sh*t about cutting springs, I cut off a dead coil.
Heres my setup: 16x7 Rota/Konig Cobras (+35mm offset), 205/45-16 Nitto NT-505's, Intrax springs w/coil cut off the back, and Tokico struts (cartridges).
With this setup I have a 2 finger gap in the front and a tad over 2 fingers in the back.
Old 06-13-2002, 06:02 PM   #9 (permalink)
Thanks for all the replies.
