Camry Lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2004, 08:53 AM   #1 (permalink)
View Super Mario's Photo Gallery
Question Camry Lights
Hey everyone, I was wondering if anyone know where the fuse's are located for the high beams on a 1990 Camry LE V6. Might I add the wiring harness is from an '88. My car caught fire last year and I replaced it with the an '88 harness. The cars starts without a problem, but the high beams don't come on, and I'm thinking it is the fuse. The wiring diagram says there is one for each beam, but it doesn't give me the location. Please help if you can. Thanks in advance.
Super Mario is offline   Reply With Quote
Old 10-27-2004, 11:54 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: Camry Lights
Fusebox under the hood.
2 15A fuses.
"Skoolin' the unlearned!"
Old 10-29-2004, 08:51 PM   #3 (permalink)
those two fuses are for the low beams i need the fuse's for the high beams...they should be seperate. and they are not even located in the junction blocks.
Old 10-29-2004, 10:15 PM   #4 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
It is possible both headlights have bad high beam elements.
According to the wiring diagram I have, the high and low beam are on the same fuse and the low/high beam is swiched though the ground. So the positive side of the circuit is the common for the headlights. High beam should be on a red wire with a blue stripe. If you have a circuit tester available try this: The Red on the left side or the Red with Yellow stripe should be hot all the time, when the light switch is on. If you ground the Red with White stripe wire the Low beams should come on. If you ground the Red with Blue stripe the High beams should come on. (This should be done with something that has a load on it to prevent a short circuit)
If both tests work you have a problem either with the switch or with the wiring in between.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 11-19-2004, 11:33 AM   #5 (permalink)
thanks for all the help guys but nothing is working...we're gonna rewire the headlights from the fire wall...once again thanks for the advice. take care
super mario
Old 11-21-2004, 08:29 PM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Did you check the relays??
Where are you in GTA?? I have a few spare 4pin Denso/toyota relays.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 11-21-2004, 09:13 PM   #7 (permalink)
the relay is brand new...thanks anyways man
