Adding footwell lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2004, 09:41 PM   #1 (permalink)
View techguy's Photo Gallery
I have a 99 Camry Le (4 cyc). I want to add footwell lights and connect them to the dome light. Where can I tap the circuit for the dome light?
techguy is offline   Reply With Quote
Old 10-28-2004, 09:46 PM   #2 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
The circuit should be the same one as the door valet lights are on. If Toyota has kept the color of the wires the same your interior lights should be on a Red wire. I've always thought pillar lights in the back pillars would be a nice touch too.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 10-28-2004, 10:05 PM   #3 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
On my 00 Corolla there is a 2 wire cable running up the drivers side A pillar (cover pulls right off easily) It contains the wires that run up to the dome lamp and you could tie lamps into these wires.
Go easy on the current draw ! ( 1 or 2 small bulbs if driven direct )
Yes, I want to add some lights myself. I used those lines and wired an LED to light the ignition cylinder. Looks great !!
CW
CraigW is offline   Reply With Quote
Old 10-29-2004, 12:53 AM   #4 (permalink)
I am planning to hook up 2 neon bars, one per front footwell. I guess I may need to put a relay.
Old 10-29-2004, 01:52 AM   #5 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
I was thinking of lighting up the rear foot wells too, from under the driver and front passenger seat.
old faithful
amerikim is offline   Reply With Quote
Old 10-29-2004, 10:18 AM   #6 (permalink)
Mighty Flying Family Sedn
View Mighty~Mart's Photo Gallery
is there any way to do this only when the door is open?
Mart~
Camry Gen 5 SE
2.4L I4 DOHC
Stock 16's
Totally stock
Mighty~Mart is offline   Reply With Quote
Old 10-29-2004, 10:38 AM   #7 (permalink)
TN's Nikon Expert?
prnc_chrmng's Avatar
Gameroom cash: $491868
View prnc_chrmng's Photo Gallery
yeah, i think al you have to do it tap into that little red light on the door, either runnig the wire all the way to the light or tapping into the fuse should work too
Originally Posted by 98tercel_girlie
This thread needs more porn, less blah blah
prnc_chrmng is online now   Reply With Quote
Old 10-29-2004, 10:44 AM   #8 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
should be the same for gen4 camry's
http://www.aircargodispatch.com/paul/tutorial.htm
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
