leaking sunroof - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2004, 12:12 PM   #1 (permalink)
View tiedyedbiker's Photo Gallery
USA leaking sunroof
Auto glass shop says leaking sunroof may only need servicing instead of replacing seal. What does servicing consist of? Their price was through the roof. Yes, pun intended.
tiedyedbiker is offline   Reply With Quote
Old 10-29-2004, 11:41 PM   #2 (permalink)
View Hossy's Photo Gallery
if its factory i doubt its the seal unless the seals torn. I'd check and make sure the drains are clear, thats the most common cause i've seen of leaks.
Hossy is offline   Reply With Quote
Old 10-30-2004, 11:34 AM   #3 (permalink)
View KMX3060's Photo Gallery
Where are the drains and how do I clean them???
KMX3060 is offline   Reply With Quote
Old 10-30-2004, 04:43 PM   #4 (permalink)
theres four, one at each corner of the track. you can see the front ones, but not the rears. i use compressed air, but a wire fished through a little should help, the rears on the cars are routed down the inner qaurters in the trunk.
Old 11-01-2004, 08:35 PM   #5 (permalink)
View toyotanut3717's Photo Gallery
Yea its the drain holes, I'd bet on it. I had a leak and used compressed air and a pebble shot out of one, still can't figure out how it got in there.
toyotanut3717 is offline   Reply With Quote
Old 04-21-2006, 11:06 PM   #6 (permalink)
View stockcammy's Photo Gallery
Anyone have any pictures of these drain holes. I can't see them and I am leaking from my sunroof. I am hoping this is the problem.
stockcammy is offline   Reply With Quote
