timingbelt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2004, 09:06 PM   #1 (permalink)
View gasman804's Photo Gallery
timingbelt
after installing a new timing belt and water pump my 2.2 camry smells hot. Also when I replaced the belt the ignition timing was retarded by about 20 deg. Any clues? I used a chilton book for reference while doing the belt.
gasman804 is offline   Reply With Quote
Old 10-29-2004, 09:57 PM   #2 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
unless you mess w/ the distributor, the timing might be off.
dont forget that when using inductive timing light, short out the thingy at the little box.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 10-29-2004, 09:57 PM   #3 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
Does your car lack its normal power at lower rpms? If so I would guess the belt is probably a tooth or two off.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 10-29-2004, 11:16 PM   #4 (permalink)
View Hossy's Photo Gallery
es is right , your probably a tooth off. Was the timing mark even on the grid? If not you are for sure off with your cam timing, wont hurt much just run real poochy.
Hossy is offline   Reply With Quote
Old 10-30-2004, 01:50 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Sounds like you didn't align the crank and/or cams properly before installing the belt.
http://yotarepair.com/5S-FEtimingbelt.html
"Skoolin' the unlearned!"
Old 10-30-2004, 01:04 PM   #6 (permalink)
Grenaded piston
88 LE's Avatar
^ Not all 5S-FEs have the sensor (crank position sensor) that your talking about.
5S-FEs with DIS (distributorless ignition system) have the sensor.
The early 5S-FEs have a distributor.
Old 10-30-2004, 02:33 PM   #7 (permalink)
97 BlackWidowed
View Porkch0p220's Photo Gallery
what years are distributorless?
Porkch0p220 is offline   Reply With Quote
Old 10-30-2004, 07:47 PM   #8 (permalink)
i believe:
for the 5sfe, 96+ are distributorless
for the 1mz, 94+ are distributorless
