Suspension Upgrade Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2004, 02:24 AM   #1 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
First off I would like to say that I have read the FAQ and searched for answers.
Alright, I would like to upgrade the suspension in my 91 camry. I checked Nopi Online and they have only INTRAX springs, and that is fine. The problem I have run into is that Nopi Online sells KYB struts for my car, but should I get the sealed or servicable struts? In the FAQ it says you can only use tociko inserts.
And a second question, will I need to upgrade the strut mounts? Or boots?
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 10-30-2004, 02:50 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: Suspension Upgrade Question
Serviceable are cartridges. They'll only work if your stock struts are serviceable/non-sealed.
Sealed = complete strut. They'll work for either (sealed or non-sealed).
You need to look at your stock struts and see if their sealed (welded shut) or serviceable (has a nut that threads into the top of the strut housing).
Theres pics in the Camry faq.
Tokicos for gen 2 Camrys only come as cartridges.
No.
"Skoolin' the unlearned!"
Old 10-30-2004, 06:06 AM   #3 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
After doing mine, if the dollar amount is neglible, go for the complete strut instead of the the cartridges. You will have a much easier, quicker, cleaner and better looking install.
old faithful
amerikim is offline   Reply With Quote
Old 10-30-2004, 01:19 PM   #4 (permalink)
userlain's Avatar
USA
Thank you 88LE for clearing that up!
And thanks for the advice amerikim!
I guess I have another question also, Whiteline sells the rear sway-bar for $130 but the 'bushings' are also $130, so do I need the bushings to install the sway-bar?
Old 10-30-2004, 01:28 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
^ The swaybar comes with bushings (polyurethane).
They also sell a complete bushing kit for gen 2 Camrys. Thats the bushings your talking about for $130.
Old 10-30-2004, 02:17 PM   #6 (permalink)
userlain's Avatar
Awesome! Thanks again 88!
