Problems with Rear Dropzone Springs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-31-2004, 07:12 PM   #1 (permalink)
View agabor's Photo Gallery
I am trying to install my dropzone springs, however my mechanic has shown me that the rear dropzone springs for my 93 camry are too short to be compressed. On the rear they are over 2" from the top of the spring/strut assembly. I didn't have this problem on the front struts as they were long & able to be compressed. My new tokico struts (in serviceable struts) are therefore too long for the rear dropzone springs along with the stock struts if I try to use them to get the dropzone's to fit. If I install & use the car with this huge gap, when my rear wheel hits a pothole the suspension would probably fly apart.
Did anyone have this problem with there rear struts using dropzone or any other lowering springs?
agabor is offline   Reply With Quote
Old 11-04-2004, 10:51 PM   #2 (permalink)
View YOTA_Power's Photo Gallery
ya mine were short but i put them in anyways and there great even with dead shocks...
YOTA_Power is offline   Reply With Quote
Old 11-04-2004, 11:04 PM   #3 (permalink)
Big Wrench
View Mikey21's Photo Gallery
Atleast you don't need a spring compressor to put the new springs in.
How about fabricating a larger (taller) spring seat (insulator) to make up the difference?
Old School Wrench/ New School Ride
My Camry Pic's
Mikey21 is offline   Reply With Quote
Old 11-04-2004, 11:14 PM   #4 (permalink)
Got the dropzones on...
Although the rear springs were much shorter then the top of the assembly I went with the installation and the springs ride really nicely with my tokico shocks. I am still worried that if I go over a pothole and the suspension opens up, it might come apart and missalign? You think this could ever happen?
If that happens I'll probably cut & machine my strut piston rods shorter or maybe go with that insulator idea...
Old 11-04-2004, 11:51 PM   #5 (permalink)
Gameroom cash: $147537
Don't worry, my coilover got no compression before install. As soon as you put the car down the spring will compress. The sturt will slow the wheel from dropping when you hit a pot hole. Unless you spent a few sec on the hole, the wheel won't drop.
Old 11-05-2004, 08:45 AM   #6 (permalink)
The Other White Meat
terrastrife's Avatar
if youre still paranoid, grab a drill, some wire, drill a hole in the lower strut and wire in the spring so it stays.
terrastrife is offline   Reply With Quote
Old 11-05-2004, 04:12 PM   #7 (permalink)
View wontonjohnny's Photo Gallery
your supposed to zip tie them on
5 speed 3vzfe - RIP
project F23 CL-T
Custom Y-pipe Project
Custom 1-Piece CAI Project
wontonjohnny is offline   Reply With Quote
