nasty yellow stuff - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2002, 01:50 PM   #1 (permalink)
View camryLI's Photo Gallery
has anyone attempted to clean the inside of the headlight covers? i got this yellow gunk on the inside, and wanted to clean them. If so how. 92gen3
--LI
1992 Camry LE: K/N Air Filter, Clear Bumper Kit, Fog Lights w/ LED switch, LED washer nozzle lights, AR Sniper Chrome Rims, Interior Glow Kit, Pioneer HU, Pioneer Speakers, JBL Mono Block Amp, 2 12" Rockford Subs, Alarm, Mica Red
camryLI is offline   Reply With Quote
Old 06-16-2002, 12:42 PM   #2 (permalink)
come on help me out!
Old 06-16-2002, 10:38 PM   #3 (permalink)
DJModifyd
alex's Avatar
View alex's Photo Gallery
I don't know for sure, but i've heard toothpaste and a toothbrush helps quite a bit.
alex is offline   Reply With Quote
Old 06-16-2002, 10:56 PM   #4 (permalink)
I has boost..!
Razo-E's Avatar
View Razo-E's Photo Gallery
i think that's all of the "minerals" that get left behind after the water trapped in the headlight housing evaporates, so tooth paste should work, or use that CLR crap, but i think that may mess up the headlight...
1986.5 5-speed '91 7MGE
1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff
1992 5-speed hardtop - 2JZ-GE
2005 Scion xB - no longer stock
Razo-E is offline   Reply With Quote
Old 06-17-2002, 01:09 AM   #5 (permalink)
I am just a newbie!
Tony the Tiger's Avatar
View Tony the Tiger's Photo Gallery
This is taken from the lighting FAQ:
How do I clean a reflector lamp?
Cleaning the outside of a headlight should preferrably be done with soap and water, and is considered very streigth forward.
However, cleaning the inside of a headlamp becomes more tricky since you will face the same challenges as cleaning the inside of a bottle:
Remove the headlight bulb.
Remove the headlight from the car.
Fill the headlight about 1/2 full of distilled water and put in a few drops of dishwashing liquid.
Cover the bulb opening and shake the housing for a minute or so.
Pour out the soapy water.
Fill the headlight about 1/2 full of distilled water.
Shake, drain.
Repeat rinse.
Rinse again with 1/4 cup of rubbing alcohol added (promotes drying).
Drain.
Let headlight dry, open end down (overnight), or you can use a hair dryer to speed things up.
Reinstall headlight.
Reinstall bulb.
* Goal for 2012 -- 200+ MPH in the Camry
Tony the Tiger is offline   Reply With Quote
