camry idles low and occasionally stalls!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2004, 03:34 PM   #1 (permalink)
View stussy02's Photo Gallery
Question camry idles low and occasionally stalls!!
i have a '93 camry v6 and it is idleing at like only 400-500 rpms. it drives fine when i am actually driving the car and at all speeds. if the car isn't warm it will usually stall out when in park or neutral. i have even driven it on the express ways and does fine when i punch it. i tried some gas treatments, but it is still doing it.
i was thinking of replacing the fuel filter cuz im not sure the last time it was done (it was my grandpa's car). i am mechanically illiterate, so where is the fuel filter located? how do i change it?
is this even the right thing to do?
i am a college student and want to avoid taking it to the shop if i can fix it myself. what do you think the problem is and can anyone help please??????
stussy02 is offline   Reply With Quote
Old 11-01-2004, 05:12 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
sounds like your cold start injector/sensor is failing you
Old 11-01-2004, 08:06 PM   #3 (permalink)
toyota tuner
vsixcamry's Avatar
View vsixcamry's Photo Gallery
you may also want to check the temperature sensor in your intake, i did not hook mine up to my CAI awhile ago thinking it would have no effect and my idle rpm would be abnormally low..
vsixcamry is offline   Reply With Quote
Old 11-01-2004, 08:20 PM   #4 (permalink)
The Smashing Pumpkins
rapsux2000's Avatar
View rapsux2000's Photo Gallery
Another problem could be your idle air control valve.
Click on the link below this sig for info and pics of my 99 Camry.
http://www.toyotanation.com/forum/t44068.html
Sohil
rapsux2000 is offline   Reply With Quote
Old 11-02-2004, 12:44 PM   #5 (permalink)
View yotacam98's Photo Gallery
Could be the IAC, or IAT like above and if you dont know when the FF was changed than that is a good idea to do anyway. Is the check engine light on?
98' Camry LE (5SFE) w/ a slushbox
K&N,Denso,Hypervoltage
yotacam98 is offline   Reply With Quote
Old 11-02-2004, 11:46 PM   #6 (permalink)
no, the just the check engine and thats only once it stalls. so i dunno if its sensors or fuel filters. it drives fine at normal speeds, just idles really really rough.
Old 11-03-2004, 12:45 PM   #7 (permalink)
View burchard's Photo Gallery
Clean the AIC. Search this site for procedure. Cleaning the IAC won't hurt. Good luck.
burchard is offline   Reply With Quote
Old 11-03-2004, 01:37 PM   #8 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
maybe a dirty EGR no fully closing.
TN Map - Add Yourself
Phi is offline   Reply With Quote
