Hi, I'm new
I drive an Automatic shift 4-cylinder '96 Camry LE. There is a clicking noise from my left wheel when I turn right. Both front axles were replaced a little under two years ago (I'll have to check on the warranty at the parts store). I suppose it should be a lesson in buying cheap parts that I'm having problems so soon!
So anyway, believe me, I've read the Hayne's manual. I've also done a search on this here forum.
Can someone give me simple instructions for checking the CV joints to see if they're the problem? I had a mechanic check it out, but he just pointed his light underneath the vehicle (with the vehicle raised, of course
) and in less than five mins said it all looked okay. Everyone else I've talked to says it must be the CV joints! So I just need to know how to check for myself if they're worn or damaged.
The last time they were replaced, the rubber covering over them was completely torn. There's no such thing going on now.
Please help.
Thanks.
PS: I LOVE this forum!!!! You all are so positive and informative! ....and I'm not just sucking up because I need help
