Problem installing header :'( help plz!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-05-2004, 11:02 PM   #1 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
My only problem installing my Pacesetter header is attaching the o2 sensor. the bung that was welded onto the header has threads for an o2 sensor to screw into. I was told buy the guy I purchased the header from that the oem sensor screws out of the mounting plate that bolts onto the oem manifold. this is not true. i also tried this on a $50 Bosch o2 sensor and broke it.
Help!
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 11-06-2004, 12:15 AM   #2 (permalink)
View deekay140's Photo Gallery
hes full of crap,, u have a header for a newer model,, return it.
deekay140 is offline   Reply With Quote
Old 11-06-2004, 12:38 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Buy a universal single wire O2 sensor (screw in type).
Cut the plug off your existing O2 sensor, solder, and heatshrink.
"Skoolin' the unlearned!"
Old 11-06-2004, 12:57 AM   #4 (permalink)
userlain's Avatar
I figured that all O2 sensors would be the same.
What is this heatshrink you speak of?
Old 11-06-2004, 01:14 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
Heat shrink tubing.
http://www.cableorganizer.com/heat-shrink
Old 11-06-2004, 01:15 AM   #6 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
it is rubber insulation for wiring, when you heat it it will shrink in size.
You'll need this because you are cutting your wire from the o2 sensor to the ecu. It needs to be patched.
- Vince
VVT-i Owns is offline   Reply With Quote
