help powersteering fluid leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2004, 03:18 AM   #1 (permalink)
View tavalon's Photo Gallery
the fluid in my powersteering RESERVOIR is going down at an adnormal rate and i have been refilling it. i have a leak somewhere and can't seem to find it. i checked the hoses around the RESERVOIR and the seem to be ok. i did notice my cv boot is alittle wet. any suggestion is appreciated.
btw car is a 98 avalon v6
tavalon is offline   Reply With Quote
Old 11-06-2004, 11:39 AM   #2 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
You just answered you own question. Its most likely the boots. My boots were both broken and I didn't notice any leaks on the street under the car. My resovoir did go down though. Turns out it leaked when I started driving around.
Its probably the same for u 2. If your boots are broken, your probaly gonna have to change your cv joints 2. Good luck with everything.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 11-06-2004, 12:15 PM   #3 (permalink)
View deekay140's Photo Gallery
The rack and pinion is leaking. poke a hole in the rack boot (not the cv boot!!!!!!!) and youll see the fluid pour out.
deekay140 is offline   Reply With Quote
Old 11-07-2004, 01:43 AM   #4 (permalink)
A Poor College Student
The Wolf's Avatar
View The Wolf's Photo Gallery
Ahhhhh.... that's probably my problem. Had a coupon for a free inspection, and they said my front seals, valve cover gasket, distributor o-ring, and rack & pinion were all leaking/needed new seals. But no fluids are vanishing at a noticeable rate, lest of all power steering.
"Your in violation of signature rule #4."
Crap.... guess I'll change it later.
The Wolf is offline   Reply With Quote
