Replacing Transmisson - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2004, 08:50 PM   #1 (permalink)
View ele1432's Photo Gallery
How hard is it to reply a transmisson out of 94 Camry ??? Its the normal 4 speed auto...also I was told that you have to drop the sub-frame to drop the tranny is that true ??? Can you take the tranny out from top ???
ele1432 is offline   Reply With Quote
Old 11-06-2004, 09:42 PM   #2 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
On my 6, they did have to drop the sub-frame. From what I understand you can take it out the top but it is not the safest way to do it.
old faithful
amerikim is offline   Reply With Quote
Old 11-06-2004, 09:45 PM   #3 (permalink)
What do you mean not the safest way to do it ???
Old 11-06-2004, 11:12 PM   #4 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
He means, that you shouldn't do it.
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 11-07-2004, 12:07 AM   #5 (permalink)
Sooo is dropping the sub frame hard...I have access to an engine lift..
Old 11-07-2004, 02:50 PM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Forget dropping the subframe unless you have access to a car lift.
The tranny can be removed from the top. I've done it twice on a gen 3 Camry.
You can either seperate the tranny from the engine and lift it out. Or remove the engine and tranny together.
I find it easier to remove the engine and tranny. Then seperate the 2 once its out of the car.
"Skoolin' the unlearned!"
Old 11-07-2004, 03:08 PM   #7 (permalink)
Auto-Cross Addict
SmokingTires's Avatar
View SmokingTires's Photo Gallery
Removing both together would be your best bet. Otherwise you have to remove the intake and numerous other parts to pull the tranny out.
Either way, if you aren't overly experienced in working on cars, I wouldn't suggest doing it yourself. FWD setups can be confusing.
I'd personally drop it out the bottom. Then you can leave the engine in. But I have access to a lift and tranny jack, so it's easier for me.
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline   Reply With Quote
Old 11-09-2004, 01:38 AM   #8 (permalink)
Thanks for the info...but I'm getting two different answers here...let me explain it better....I have one day to put this tranny in...I have done many engine swaps one other car...VW GTI...I can have the engine out in about 2 hours...can the same be said about the Camry ??? Also is the Haynes manual at Auto Zone a good manual to pick up ??? It did a very poor job covering my dub...oh..is replacing the tranny filter and fluid hard ??? And do you pour the new fluid down the tranny dipstick ???
Oh one more thing...there is a big crossmember below the tranny can that crossmember be removed ???
Old 11-09-2004, 02:26 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
No.
1. Drain out old fluid. Theres a drain bolt (10mm hex) on the tranny pan.
2. Unbolt tranny pan.
3. Unbolt the filter. You'll see the filter on the bottom of the tranny after you remove the pan.
Yes.
Yes, it can be removed.
But unless you have access to a lift and something to support the engine/tranny, forget it.
Old 11-09-2004, 02:47 AM   #10 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Never pulled a transmission, but if it were me I'd take this oportunity to pull that '94 engine and check the water/oil/ps pumps ect... while it's out of the car.
Who knows, you might find something about to give up the ghost and catch it!
AIM/Yahoo Toysrme257th
Now with Turbo!
