replacing timing belt.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2004, 10:34 PM   #1 (permalink)
View tightcamry129's Photo Gallery
hey guys, i just got quoted at the dealership to get my timing belt replaced. Now i'm just wondering if i should just get the belt? or the whole timing belt kit? And what's a tensioner? Do i need to purchase it so they can install it?
tightcamry129 is offline   Reply With Quote
Old 11-09-2004, 01:18 AM   #2 (permalink)
Gameroom cash: $927300
iTrader Score: 13 reviews
View ASG14's Photo Gallery
I called up Toyota last week for a timing belt and water pump replacement and they were all around $600. One dealership quoted $630 for the belt and pump, plus thermostate and assesory belt.
5 Lug Corolla WHAT?
Old 11-09-2004, 09:09 AM   #3 (permalink)
View Tony J's Photo Gallery
If you change the timming belt, you should change the water pump also. I had a water pump lock up and it will take out the timming belt
Tony
Tony J is offline   Reply With Quote
Old 11-09-2004, 11:00 AM   #4 (permalink)
Gameroom cash: $147537
You need to remove the following to get the timing belt out:
Passanger side motor mount
Top belt cover
Under engine plastic cover
Crank pulley-need pulley puller
Lower belt cover
Don't know how hard it is to do with engine in the car.
You can get a rebuild water pump for around CAN$70.
Old 11-09-2004, 12:36 PM   #5 (permalink)
View Camry6785's Photo Gallery
not hard, just take your time, replace all the belts unless there are low miles on the others. save yourself some time
R34 Front Bumper For SALE
CLICK THE LINK FOR THE THREAD
http://www.toyotanation.com/forum/t55782.html
Camry6785 is offline   Reply With Quote
Old 11-09-2004, 02:18 PM   #6 (permalink)
Hey guys, thanks for all the replies. But i don't think i was more specific in my post earlier. I'M NOT doing the timing belt myself. Somebody is doing it for me in their garage. He told me to get the belt at the dealer and i'm just wondering if i should get the whole nine yards or just the timing belt and the water pump. Thanks.
Old 11-09-2004, 02:41 PM   #7 (permalink)
Do as much as you can while the cover is off. Also check the main seal on the crank to see if it got hard and brittle already, change it if it is. Spin all the rollers and replace them if they're hard to turn or not running smooth.
Old 11-09-2004, 02:51 PM   #8 (permalink)
grrroarr... ?
View jaguar's Photo Gallery
when i changed my timing belt i replaced the tensioner pulley and some other pulley.
i recommend you change, or have it changed, while you're at it.
also have a look at the other belts (alternator, steering pump)
94' 2.2 Camry
-fast enough to get tickets-
jaguar is offline   Reply With Quote
Old 11-09-2004, 07:09 PM   #9 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Can you just slide the old belt off and slide the new one on in the same place? I mean replace the tensioner of course...
97camryman is offline   Reply With Quote
Old 11-09-2004, 07:55 PM   #10 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
you probably can slide the old power steering belt and alternator belt off if you loosen the adjustment bolts. i don't think it is possble to slide the old timing belt off and replace the tensioner with out taking off the crank shaft bolt and take crank shaft pulley out to remove the lower timing belt cover.
bronzemaxell is offline   Reply With Quote
Old 11-09-2004, 08:07 PM   #11 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
If this is the 2nd time you're getting the timing belt, then yes, do the water pump too.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
