V6 Camry Timing
I own a 88 Camry with the 2VZFE motor.
Im having problems with the timing.
The motor pings under acceleration and wants to stall when it's hot at idle in a drive gears (its ok in P or N).
I wanted to see what the timing was set to, but i can't seem to figure out how.
I can see the timing block with 15-10-5-0 etc on it, but there is not marker or something to see whats it's actually set too.
Also, because of access, I have got the timing light on the 2nd cylinder spark plug (Front bank Left). Is this ok?
Also, is there any electrical things that require doing like shorting pins or simething on the DIAG connector?
Performance is still ok off the line, could be better, and it is hesitant WOT.
Our premium petrol here is 98 RON, 87 MON minimum. I am using the regular version, so the petrol I have in the car now will have a lower rating. Is this acceptable?
Thanks heaps.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
