Re: cv axle help! (pass.)
Originally posted by bequick
well I put in a new axle because I broke the bearings in the knuckle but it still doing the whining/grinding noise on the pass. side. The axle is BARELY spinning, but the driver side is working fine so I don't think its the tranny, I could be wrong tho. Can the axle still be loose by the tranny that causing this whining/grinding noise? Im in desprite need of some help.
wheel bearings will cause it, did you break one of those? what part of TX are you in? there is a toyotoa shop in dallas (garland) called JP imports, he does toyota/lexus only and is going to do my inner and outer cv joints (entire axle replacement on each side) and a tranny drain and fill for me.
2006 Honda Civic EX in Galaxy Gray Metallic Pearl-WR Blue Brake Calipers, Ipod Integration, Debadged, K&N Drop-In, Mobil 1 Synthetic oil, Bridgestone Turanza 215-55-R16 Shoes, RedStuff Ceramic Brake Pads, Tint w/3m SolarGaurd film: 5% rear, 15% front, 30% moonroof
