Originally posted by Toysrme
btw what work have you done so far wibbit? Sounds like you've found some extra power, cause it won't burn one tire up unless you're really up the rpm range when you dump the clutch!
last time i dynoed the car i had about 120kW@the wheels, it should be a tiny bit more today with the CDA and high flow cat. If i launch at 3000rpm the car will spin one wheel and wanna turn left as a result. also on corners the outside wheel can be jus slipping away. this is all on dry road
Originally posted by CamryWhat?
Soundlzd (sean from CTMotorsports) has on his and he likes it a lot!!!
yeh hes the one im buying it off if i do buy it.
Originally posted by terrastrife
try new tyres first... a much cheaper option. i can absolutley smoke my front right if im turning right in my car...right handers are a bit hairy, but a left hander is silky smooth. maybe if you can find a 1.5 way lsd... a 2.0 way is a bit too much for a fwd daily driver.
but.. tyres first.
yeh im looking into the 1.5 way LSD. my current tyres are goodyear F1s, good tread on the front. I will get 225/45 sports tyres as soon as my Gram Lights arrive.
Originally posted by Wraith
I love my Kaaz lsd ... Plus I know the President of Kaaz USA ... Awesome set of guys over there...
So you getting paid how much to say that?
Is it overly aggressive or smooth enough to be on a daily?
