3VZ-FE engine 3.1 litre A/T fluid correct???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2004, 01:33 AM   #1 (permalink)
View 94_v6_camry's Photo Gallery
Hi,
Can someone tell me what is the correct way to change the automatic tranmission? On the Haynes book it said for 3VZ-FE engine it's 3.1 litres and the Differential is 0.76 litres.
So after draining the A/T all i need to do is add the 3.1 litres??? How can i get to the Differential and where it's located???
Thanks
94_v6_camry is offline   Reply With Quote
Old 11-11-2004, 02:22 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Tranny
1. Drain the fluid. Theres a drain plug (10mm hex) on the tranny.
2. Fill the tranny through the dipstick.
Differential
1. Drain the fluid. 10mm hex drain plug.
2. Fill with fluid. Theres a filler hole on the backside of the diff. You need to remove a 17mm bolt.
"Skoolin' the unlearned!"
