Well going off on a limb, the 3vz-fe heads would probably fit, seeing how the 2vz/3vz both have 87.5mm bores. Assuming the rest of the VZ block didn't change much and the coolant/oil passages lined up, there still wouldn't be much point to it. If you want more power from the heads just have the stock heads ported & polished.
AIM/Yahoo Toysrme257th
Now with Turbo!
