Ive got ERROR CODES!! Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2004, 04:48 PM   #1 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Ok...i checked my error codes wit the CEL.
This is what it retrieved:
Code 12 - RPM Signal - No "NE" or "G" signal to ECU within 2 seconds after engine has been cranked.
Code 24 - Intake Air Temp Sensor Signal - Open or Short Circuit in IAS signal (THA)
Code 31 - Air Flow Meter Signal - Open circuit in VC signal or short btw VS & E2 when idle contacts closed.
Code 41 - Throttle Position Sensor Signal - Open or Short circuit in TPS Signal.
Can anyone help me in what I should do about these?? It seems the last 3 are replaceable sensors..the first one tho.. im not sure about.
Any info would be appreciated. Thanx.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 11-11-2004, 06:25 PM   #2 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
Check your fuses.
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 11-11-2004, 06:52 PM   #3 (permalink)
VeeZed
Can you give me more information plz?
Which fuses and why?
The manual ive got is sayn that those parts are faulty. So id replace all of those sensors?
What does that first one mean...whats it refering too?
Old 11-11-2004, 08:36 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
12 = distributor or ecu
24 and 31 = AFM
41 = TPS
http://www.autozone.com/images/cds/g...3d8013ee24.gif
http://www.autozone.com/images/cds/g...3d8013ee25.gif
"Skoolin' the unlearned!"
Old 11-11-2004, 08:52 PM   #5 (permalink)
VeeZed
Thanx 88LE. Still though..i need info on what to do about these. Lets say we look a code 41..TPS. Should i just replace it?? Same with the AFM?
Can u explain what these codes mean in a little more english. I understand what the charts says...but in english what is it sayn is wrong and what to do?
Are these serious warnings?
The car hasn't been running well for a couple of weeks now..so maybe these are the causes.
Thanx.
Old 11-11-2004, 09:36 PM   #6 (permalink)
Grenaded piston
88 LE's Avatar
You can check the AFM and TPS for resistance.
You can also check for resistance at the ecu.
ECU schematics
Page 1
Page 2
Troubleshooting info
Page 3
Plugs
Page 4
Page 5
All the diagrams are for a SV21/SV25 (3S-FE). You have a VZV21 (2VZ-FE), but you can use the diagrams and see if anything crosses over to your car.
How to use the diagrams
Lets say you wanted to check the AFM.
Looking at the troubleshooting info you'll see that the plug for the AFM is "H".
You then look at the "plug" diagrams and you'll the pinout for "H".
So you pull the plug for the AFM and measure the resistance at the AFM based on whats given in the troubleshooting info.
Old 11-11-2004, 10:30 PM   #7 (permalink)
VeeZed
Thankyou very much 88LE. Much appreciated.
One quick question.
In the diagrams where is specifies the resistance btw certain points, i dont understand one of its conventions.
For example
I understand: (H) 1-2 : 13.8ohms ... etc etc
That would be..on connector H (AFM) btw points 1 and 2, resistance should be 13.8 ohms.
I dont understand: (K) 1- (K) 4: 3-7kOhms.
Btw wat points is this talking about??
Pin 1 to Pin 4 of K connector??
Is weird because i wouldve thought that would be represented as (K) 1-4 : 3-7Kohms.
Thanx.
Old 11-11-2004, 10:49 PM   #8 (permalink)
Grenaded piston
88 LE's Avatar
Yup, pin 1 to pin 4 on plug K.
Its just labeled weird.
You'll notice the same thing for the R, S, and T plugs.
