gauge help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2004, 07:42 PM   #1 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
'93 Cam LE gauge help
I've been noticing lately that when i put on my lights, my gauge lights take a while to come on or don't come on at all. Everything else works fine except for this and when it does come on it blinks with my bass. Not a little dim like headlights, but more noticable. What could the problem be?
http://www.xclusive.bz
Old 11-11-2004, 09:07 PM   #2 (permalink)
View 97 camry xle's Photo Gallery
have you tried playing with the dimmer switch?
*rehab is for quitters*
'97 camry xle
'92 bmw 535i
97 camry xle is offline   Reply With Quote
Old 11-12-2004, 05:21 AM   #3 (permalink)
dna59's Avatar
^yes I have. doesn't seem to do anything
Old 11-12-2004, 06:07 AM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
loose wiring/soldering/connection... sub making the wires loose contact, also with time duration wires heat up and conduct better... maybe?
terrastrife is offline   Reply With Quote
Old 11-12-2004, 06:32 AM   #5 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Loose connection. Try to GENTLY stress wires and connectors and look for flickering/on-off. Also make sure those are the only lights that are out at that time.
Is it all of the dash lamps or just the gauge if all concentrate on the dimmer unit and connectors, If gauge remove and re-seat the connector on the back of it.
CW
CraigW is offline   Reply With Quote
Old 11-12-2004, 12:17 PM   #6 (permalink)
dna59's Avatar
yes the gauge is the only light out. well i have a neon connected to light up when the lights are put on and that does the same thing. all other lights work perfectly.
Old 11-12-2004, 12:38 PM   #7 (permalink)
Did you by chance tie the neon into the dash lamp circuit (the bulbs that dim with the control knob ??) If so I would change it.(too much current for control unit)
I would re-seat connector at speedometer.
And maybe look at the connection for the neon it could be the source of trouble. (if it is on the same circuit)
Old 11-22-2004, 09:25 AM   #8 (permalink)
dna59's Avatar
I tried everything and now it still doesn't work. I messed around with the dimmer, unplugged and replugged all connectors, checked bulbs, and took off the neon and folights that were wired to come on wiht the lights. None of this worked, maybe I didn't explain it good enough. All my headlights, tail lights work, also all the light on the dash work (ABS, Brake,etc.) no fuses are blown or anything. ONly the light for my gauges won't come on (Speedo, Tach, Fuel, Temp.). Those are the only light that don't come on. Sometimes they come on after a while and sometime they don't at all. I had my neon and foglights wired to come on w/ the parklights, I had cut off the cig. lighter bulb and used that as a power source, but I have disconnected both and my lights still hasn't come on. Any help would be appreciated since this really bothers me while driving at night.
Old 11-22-2004, 11:20 AM   #9 (permalink)
It sounds like a loose connection. Have you pulled the speedo unit out and inspected ?? Does it use standard #194 bulbs for illumination?, you could try to remove and re-seat those.
Old 11-22-2004, 12:27 PM   #10 (permalink)
dna59's Avatar
^ I tried pulling out the bubls and re seating them but that does nothing
