Engine timing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2004, 12:50 AM   #1 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Engine timing
I just checked my timing and it was at 15 degrees!!! This is not what i expected because the car hasnt been running right and is hesitant. Could the timing be too high?? And if so would that reduce performance?
Normally i have thought the retarded timing makes for lower performance, but could this higher timing (5 above normal) be causing reduced performance.
When using regular petrol, it pings under WOT. Premium doesn't ping.
Thanx.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 11-12-2004, 01:08 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Advancing the timing usually gives better performance to a certain point (before it starts pinging).
I would set the timing to what its suppose to be or keep running premium.
Pinging/detonation is not good.
"Skoolin' the unlearned!"
Old 11-12-2004, 08:22 AM   #3 (permalink)
View deekay140's Photo Gallery
did u jump the short before checking timing?
deekay140 is offline   Reply With Quote
Old 11-12-2004, 08:18 PM   #4 (permalink)
VeeZed
Yes i did.
I have now put the timing back to 10. It seems to like it alot more. The power delivery feels a bit smoother and there is no pinging.
Old 11-30-2004, 01:00 AM   #5 (permalink)
View timmythturtle's Photo Gallery
hi,
i am having a similar problem but when i tried to jump the short to fix the timing the engine tried to correct it but the timing stayed the same. any special instructions on resetting the timing? I have also been having a ticking noise. could that be caused by the advanced timing?
timmythturtle is offline   Reply With Quote
Old 11-30-2004, 08:40 AM   #6 (permalink)
Mad Scientist-In-Training
toyrolla's Avatar
View toyrolla's Photo Gallery
Originally Posted by timmythturtle
hi,
I would carefully go over the procedure step-by-step.
Here's the step-by-step procedure provided by 88LE:
http://gen2camry.proboards26.com/ind...num=1073653372
Regards,
Toyrolla
__________________________________
88 I4 Slushie *sold*, 89 I4 5Sp *sold*, 89 V6 5Sp *sold*, 82 Corolla, 72 Datsun 510, 88 Toyota Minitruck.
toyrolla is offline   Reply With Quote
Old 08-04-2005, 06:37 AM   #7 (permalink)
INEED$
captainzib's Avatar
View captainzib's Photo Gallery
First off I want to apoligize to everyone for resurrecting a dead thread, but I want to know if advancing timing on a gen 3 with the 1mzfe will actually give any better performance, and what should I advance it to? I ran a search of "advanced timing" and this seemed to be the most helpful result so far. Any further help would be greatly appreciated.
-Ali
captainzib is offline   Reply With Quote
Old 08-04-2005, 06:49 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
^ Theres no easy way to advance the ignition timing on a 1MZ-FE.
1MZ-FE has DIS (distributorless ignition system). So theres no distributor you can turn to adjust the timing.
The ignition timing on a 1MZ-FE is controlled by the ecu and determined by sensors (cam and crank position sensor).
Old 08-04-2005, 07:37 AM   #9 (permalink)
INEED$
captainzib's Avatar
Thank you, that's as simple a response as I could have hoped for.
-Ali
