engine Q?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2004, 03:23 PM   #1 (permalink)
View toyocamboi's Photo Gallery
Question engine Q??
what is that noise when i rev the motor up from under the hood i hear either a clicking or clunking noise not constantly just right wen i rev it up and when i hea that sound it seem like the motor don't want to rev up but it only does it every onece in a while or while i take off at the light??
BLk Camry 98-6cyl 1mz
toyocamboi is offline   Reply With Quote
Old 11-12-2004, 08:14 PM   #2 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
Re: engine Q??
it could be motor mount or valve tick...
motor mount = easy fix
valve tick = oouch
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 11-12-2004, 09:40 PM   #3 (permalink)
Carzz R Xpensive!!111
felkajamine's Avatar
iTrader Score: 11 reviews
View felkajamine's Photo Gallery
how long has it been since the last oil change...if it's been awhile, then get it changed as soon as possible. make sure your oil/idiot light aint on.
check the oil dude
or it could be a sticky valve like wraith mentioned
'95 5spd Scepter Coupe
felkajamine is offline   Reply With Quote
Old 11-13-2004, 03:39 PM   #4 (permalink)
Q
what would cause the valve to stick
Old 11-13-2004, 07:15 PM   #5 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
Re: Q
just mileage and wear and tear...
MySpace:
Old 11-14-2004, 08:09 AM   #6 (permalink)
Q
how much would it cost to repair that? it only happen every once in a while and most off the time it only happen when im under the hood reving it not a clunk sound its more like one loud click and the motor hesitate alittle. after that its fine.. it never did that before i had an intake in. and also the intake is custom.
Old 11-15-2004, 05:54 PM   #7 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
Re: Q
depending on if you have hook ups at shop... Anywhere from $500 to $2000 and that is also depending on what they do to your head and how extensive the damage is ...
MySpace:
Old 11-16-2004, 01:42 AM   #8 (permalink)
try some lucas oil, it'll do some good
