1st to 2rd Gear Not Smooth (Automatic)!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2004, 05:48 PM   #1 (permalink)
View 94_v6_camry's Photo Gallery
Hi,
I got a Auto Gen3 Camry, my car not smooth when changing from 1st gear into the 2rd (Automatic)?? Is there a quick fix for it???
Thanks
94_v6_camry is offline   Reply With Quote
Old 11-12-2004, 06:28 PM   #2 (permalink)
yah ..... okay
View Neon's Photo Gallery
Not smooth.
do you mean there's hesitation ?? or the car jerks when it shifts ?? or the engine does not even want to rev higher ???
Neon is offline   Reply With Quote
Old 11-12-2004, 06:32 PM   #3 (permalink)
My car jerks when shifting from 1st to 2rd!!!
Should i be looking at changing the Automatic fluid????
Cheers
Old 11-12-2004, 07:39 PM   #4 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Or topping it off if it's low.
Are you sure you didn't just play around with the transmission kick-down cable too much when you were messing with it a week ago? Put it back more towards the middle if you don't like it shifting harder.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 11-12-2004, 07:43 PM   #5 (permalink)
View Derrick's Photo Gallery
Usually when i move from P to R there is a big shack...after i muck around with the "Kick down cable" there is not much of a shack from P to R.
But just the 1 st to 2 rd jerks hard!!!
One more thing if i decided to change the Automatic Tranmission fluid...do i need to warm the fluid first b4 chaning?????
Cheers
Derrick is offline   Reply With Quote
Old 11-12-2004, 07:51 PM   #6 (permalink)
migoreng's Avatar
View migoreng's Photo Gallery
my gen 5 camry makes a cracking sort of noise when going from P to R. but that only happens when you park on a hill when the P is holding the car more than the handbrake.
it can be done by just simply stopping on a hill, keeping the foot brake on, moving the selector to P, pull the handbrake up and then let go of the foot brake. after you let the footbrake go the car will most of the time move slightly because the handbrake needs to 'catch' or something. also when the car moves slightly like that the P gear also gets some weight put on to it.
so when you return to your car to drive off, move from P to R you will hear some crack sound.
my mum does this heaps. she doesn't pull the handbrake up completely so most of the weight of the car is held by the P gear.
i park the car differently. i keep on the foot brake, pull the handbrake up, move the selector to N then let go of the foot brake. the handbrake will be holding the car, then i move the selector to P.
there is no crack sound when i change from P t o R.
when my car was in for repairs before we got a gen 2 to drive around. it had the jerk going from 1 to 2...daym...oh well
migoreng is offline   Reply With Quote
Old 11-12-2004, 07:54 PM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^^ Uhh.. Why do you have 2 accounts?
Better hope Ratko or Ekam doesn't find out. Otherwise you'll be
"Skoolin' the unlearned!"
Old 11-12-2004, 07:54 PM   #8 (permalink)
The Other White Meat
terrastrife's Avatar
my gen3 does that too. a long time ago i read that a tranny fluid change may fix it (searchy) but its done it for 10 years, itll do it for another 10 years with no problems =)
terrastrife is offline   Reply With Quote
Old 11-12-2004, 08:18 PM   #9 (permalink)
Sorry it's the same account i just use diff browser, it won't happen again i will use 94_camry_touring.
Old 11-12-2004, 08:35 PM   #10 (permalink)
Grenaded piston
88 LE's Avatar
I was refering to 94_v6_camry and Derrick.
Thats 2 accounts.
Your already breaking the rules by having 2 accounts, don't go register for another one.
Rules:
http://www.toyotanation.com/forum/t1779.html
See rule #4.
Old 11-12-2004, 08:41 PM   #11 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
^^^ Hahahahaha. Thats a classic.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 11-12-2004, 10:39 PM   #12 (permalink)
I just change the A/T fluid, i can't get the Differential plug to open, so hard and it's not much room as well.
How important to change both at the same time???
Old 11-12-2004, 10:53 PM   #13 (permalink)
Toysrme's Avatar
Cool
I bet 99% of this board has never even checked the fluid level of their diff, even less change it. It's one of those "I'll get around to it" fluid changes.
As much as I harp about basic maint., especially fluid changes, it's not your most pressing issue.
Now with Turbo!
Old 11-12-2004, 11:46 PM   #14 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
When my Cam started jerking..I went for a full fluid flush, it cured it for about 100 miles. I thought it strange that it was about 100 miles after I bought the car.
Then the vibration started.
Fast forward >>
One replaced trannie later and many dollars poorer.
Danger, Danger!!!
Always check your tran fluid boys & girls.
old faithful
amerikim is offline   Reply With Quote
Old 11-13-2004, 12:34 AM   #15 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
You could use GM Syncromesh to align the syncros in the tranny.
It works wonders.
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
